Hey all,
My partner and I just finished shooting an event and our camera's times are a bit off by 1 hour. To make sorting and editing easier, I want to adjust my RAW files' shoot time. Is this possible?
EOSBoy Goldmember 1,083 posts Joined Jan 2008 Location: Panama City, FL More info | Feb 27, 2012 11:56 | #1 Hey all, http://patrickengman.com
tonylong ...winded More info | Feb 27, 2012 12:59 | #2 What software do you have? Lightroom has a date/time adjustment function, but I don't know about other apps for Raw files. Tony
Feb 27, 2012 13:09 | #3 tonylong wrote in post #13976861 What software do you have? Lightroom has a date/time adjustment function, but I don't know about other apps for Raw files. I have Adobe's CS5 creative suite and Lightroom. I'll look into LR and see if I can change the settings, thanks! http://patrickengman.com
tonylong ...winded More info | Feb 27, 2012 13:15 | #4 In the Lightroom Library module check the Metadata/Edit Capture Time function. I believe it does save the changes to the file, although you may want to check the Lightroom Help for specifics. Tony
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Feb 27, 2012 14:47 | #5 http://jpgtime.learsy.com/ Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Feb 27, 2012 15:12 | #6 tonylong wrote in post #13976947 In the Lightroom Library module check the Metadata/Edit Capture Time function. I believe it does save the changes to the file, although you may want to check the Lightroom Help for specifics. Thanks! I managed to push my time ahead by an hour which worked perfectly. Thanks for the help! I think I've got this handled, now. Good stuff. http://patrickengman.com
tonylong ...winded More info | Feb 27, 2012 16:09 | #7 EOSBoy wrote in post #13977658 Thanks! I managed to push my time ahead by an hour which worked perfectly. ![]() Glad it worked! Tony
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Feb 27, 2012 16:27 | #8 tonylong wrote in post #13978070 Glad it worked! Did you verify that the Raw file was indeed modified, just by using the Change dialog? I'm asking 'cause I haven't messed with it myself, and am wondering if you would have to do a "Save Metadata to File" command...? "Save Metadata to File" is the command to write an xmp file. It has nothing to do with the original RAW. Elie / אלי
tonylong ...winded More info | Feb 27, 2012 20:39 | #9 tzalman wrote in post #13978193 "Save Metadata to File" is the command to write an xmp file. It has nothing to do with the original RAW. Yeah, I know that's what it's designed to do...I just seemed to recall that you may need to do something "extra" with the Capture Style change, but like I said I never tried it and was curious... Tony
Feb 28, 2012 14:34 | #10 tonylong wrote in post #13979822 Yeah, I know that's what it's designed to do...I just seemed to recall that you may need to do something "extra" with the Capture Style change, but like I said I never tried it and was curious... Hmm good point. I'll have to check it out. As far as my workflow, it allowed me to put everything in order which works out just fine. I'll have my partner export the files and we'll see if they're still in order. I can't remember if there was a save option but I'll take a look. http://patrickengman.com
tonylong ...winded More info | Feb 28, 2012 14:42 | #11 If you Export it will definitely save the changes. My question is to whether the changes were saved into the original Raw file. For example, if you look at the Raw in something like DPP or Photoshop, will it show the correct capture time? Tony
Feb 29, 2012 10:39 | #12 tonylong wrote in post #13984812 If you Export it will definitely save the changes. My question is to whether the changes were saved into the original Raw file. For example, if you look at the Raw in something like DPP or Photoshop, will it show the correct capture time? You should be able to check also by just looking at the date/time in your file browser. But, if you only work on the original in Lightroom it shouldn't matter, since other stuff won't care until it's exported. Ohhhh, okay. That makes sense. I just changed the time, exported the jpeg and went back to check on the .CR2 file's properties and the time was still intact. http://patrickengman.com
| Latest registered member is semonsters 1676 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
