Thread started 28 Feb 2012 (Tuesday) 14:03
I think I fixed my Sigma 50mm Focus issue!
MattD
Feb 28, 2012 14:03 |  #1
Hi guys and gals!,
thought some of you might be interested in this....
I recently came across a post by gravy graffix (see post 20) where he discussed removing the shims....Well, I tried it and it seems to work.
A little explanation....my Sigma 50mm always front focused at long distances but not at short, if I adjusted it via MA it would fix the long distance, but cause issues at shorter distances, so basicaly up till now Iv just put up with it.
So today I thought Id have a go at removing some shims...I ended up removing both (!) and it now front focuses at both the short range and long range....while this may sound bad its infact fantastic! Iv now used MA +15 and it now consistently focuses at both long and short distances!
IMAGE: http://farm8.staticflickr.com/7043/6792934186_cb6d368f2d_o.jpg
Now, i dont want to give a fails impression - Iv not fully tested it yet, Iv only run some tests around the house. But this weekend I hope to do a proper field test.
For those intrested in trying it...Its fairly simple, simply remove the four screews on the metal mount, lift the mount carfully as there is a ribbon connecting it to the lens (you do not need to unplug the ribbon). Holding the mount away from the lens you can remove the shims over the mount. Its my understanding that in some cases you may need to add shims (no idea where you buy them from) but in my case I got better results by removing both.
Flickr (external link).
500PX (external link)
Twitter (external link)
Tumblr (external link)
mtimber
Feb 28, 2012 14:33 |  #2
Looking forward to some tests.
"Lovely photo, you must have a really good camera"
flowrider
Gallery: 127 photos
Feb 28, 2012 14:54 |  #3
Very cool
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
idsurfer
Gallery: 95 photos
Feb 28, 2012 15:40 |  #4
What are you considering long distances? Thanks
Cory
Sony ⍺6700 | Sony 10-20/4 | Sigma 56/1.4 | Tamron 17-70/2.8
Feedback
umphotography
grabbing their Johnson
Gallery: 21 photos
Feb 28, 2012 15:45 as a reply to  @ idsurfer's post |  #5
I Think i would send it back and buy a canon
Mike
www.umphotography.com (external link)
phreeky
Feb 28, 2012 16:32 |  #6
umphotography wrote in post #13985189 (external link)
The alternative, the Canon, is probably one of Canon's most unreliable lenses especially in the AF department. It would be great if Canon offered a genuine alternative of similar standard to their 28 F/1.8 and 85 F/1.8, but unfortunately they do not.
flowrider
Gallery: 127 photos
Feb 28, 2012 17:14 |  #7
I was under the impression the equivalent lens would be the Canon 50 1.4 which has decent autofocus and is cheaper than the Sigma equivalent unlike the 1.8 you're describing.
~Steve~
ljason8eg
Feb 28, 2012 17:20 |  #8
flowrider wrote in post #13985753 (external link)
I'm pretty sure phreeky is talking about the Canon 50 1.4. In my experience, unreliable is putting it mildly.
Jason
Gear: 1D Mark III | Rokinon 14mm f/2.8 | 24-105 f/4L IS | 70-200 f/2.8L | Tamron 150-600 f/5-6.3 | 580 EX II |
phreeky
Feb 28, 2012 17:22 |  #9
ljason8eg wrote in post #13985797 (external link)
Yep, the 50 F/1.4 is what I was talking about. It is a fragile lens that is a step below the other FLs I listed (28mm and 85mm) and could do with an upgrade to their standard, but unfortunately I can see Canon skipping that and going straight for a super expensive IS version.
MattD
Feb 28, 2012 17:38 |  #10
I used to own the canon 50mm 1.4 and I was not a fan.... Plasticky build, clicky motor that would somtimes just stop working, and strange ghosting at f1.4...
That said, it focused better than the sigma,but that's the best I can say about it.
Even with the Sigmas random AF issues I still would choose it over the canon version.... Not the L though.....if only I had the money!
Iv done some more testing...and it's still focusing well. I would say at f1.4 80% of test shots I could not ask for better accuracy. The other 20% are slight miss focuses or user error. But, I am yet to try some any long distance shots.... It could be the lens fails miserably at that distance now with the shims removed!
MattD
Feb 29, 2012 09:10 |  #11
update - Im sorry to say removing the shims has not worked - nether has removing just the one of the two..
While removing them alowed me to nail focus inside the house (and upto around 20 meter distance), when focusing on the horizon the focus was wildly out...every single time.
angeloop
Joined Jul 2016
Jul 18, 2016 11:44 as a reply to  @ MattD's post |  #12
I'm sorry to respond to an old thread.
I recently picked up this lens from an ebay auction for just $220, but it is front focusing. Anyway, I still use it as a portrait manual focus lens, and it gives acceptably sharp images wide open, and nice and smooth bokeh, so I like it.
As I use this lens just for portraits and the objects will never be as far as 20 meter or longer, I think I will try this mod.
Thank you for sharing.
05Xrunner
Goldmember, Flipflopper.
Gallery: 52 photos
Jul 18, 2016 11:53 |  #13
I have owned 4 of the Sigma 50 1.4 int he past. and my current one was giving me issues it was all over and very inconsistent.
I sent it to sigma and they did whatever to it and it came back being able to MA it and it is very consistent in focusing now. the only time I have issues is at 1.4 at the min focus distance. it seems to front focus just a little bit
My gear
R7, 7D, Canon RF 14-35 f4L, Canon RF 50 1.8 STM, Tamron 70-200 G2, Canon 100-400LII, Canon EF-RF
angeloop
Joined Jul 2016
Aug 04, 2016 10:12 as a reply to  @ 05Xrunner's post |  #14
I would really like to send mine to Sigma, but the country where I live does not have Sigma service center, and it would be very expensive to send it to USA. I'm afraid I'm on my own here. I will try to remove the rings as soon as I get a thin screwdriver.
11,580 views & 1 like for this thread, 9 members have posted to it and it is followed by 2 members.
1471 guests, 130 members online
