Thread started 29 Feb 2012 (Wednesday) 20:52
Landscape lens (again)
peteg1
Gallery: 206 photos
Feb 29, 2012 20:52 |  #1
At last, I’m getting a full frame camera and more than likely I will preorder the new 5D III or just get a 5D II. Most of my landscapes shots are between 20-35mm and f/11 or above, I’m looking at 24-70, 24-105, 17-40. Does one of these lenses stick out or something else used for around 1k.
Zenfolio (external link)
ejenner
Gallery: 98 photos
Joined Nov 2011
Mar 01, 2012 18:17 |  #2
I think the 17-40L actually does better at 24mm at f8-f11 then the 24-105.
Dare I say it - particularly in the corners. Yes, even though the 17-40 has a bad reputation in the corners and you still get people saying the 24-105 is 'as sharp as a tack', the above is true in my experience.
Plus you can go wider than 24mm.
I'm a little biased because I use 17-24 mm a lot, and have tested the overlap of these at f5.6-f16 and the 17-40 wins.
However, if you think 24mm is really going to be wide enough, then the 24-105 gives you that extra flexibility of FL + IS. But purely for IQ in the f7-f16 range; the 17-40 has the edge (to the edge).
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Mar 01, 2012 18:23 |  #3
For 20-35mm @ f/8+ I don't see any reason to do anything other than the 17-40, really; although I don't have any hands on usage of that one, myself. As the previous poster mentioned, if you can comfortably get away with 24mm as your widest angle, the 24-105 really is a very nice lens that I use a lot (albeit as a standard telephoto on my 7D/40D).
DreDaze
Gallery: 49 photos
Mar 01, 2012 18:58 |  #4
are you talking 20-35mm on your current lenses? or did you already factor in the crop factor?
Andre or Dre
gear list
Instagram (external link)
peteg1
Gallery: 206 photos
Mar 01, 2012 19:04 |  #5
DreDaze wrote in post #14001536 (external link)
Yes, with crop factor. I'll start looking for a 17-40 new or used after I see the price of the 5D3.
Thx guys.
rick_reno
Mar 01, 2012 19:21 |  #6
i like the 17-40 for that kind of application.
noisejammer
Mar 01, 2012 21:31 |  #7
If you're after a zoom, the 17-40 is capable of some excellent images and it's competitively priced. If you were after a couple of primes, you might be able to purchase quite a few elderly ones for a kilodollar. The OM Zuiko 24/2.8 compares really well and excellent copies can be found for $200.
You would however be loosing autofocus - depends whether that matters to you or not.
Several cameras and more glass than I will admit to.
1,610 views & 0 likes for this thread, 6 members have posted to it.
1459 guests, 130 members online
