Thread started 03 Mar 2012 (Saturday) 04:19
What macro lens ?
lounroxluv
Joined Feb 2012
Mar 03, 2012 04:19 |  #1
I really love all the macro shots and I'm thinking I need a macro lens. My question is what one would be the best without breaking the bank? Just want some opinions or a point in the right direction. Thank you :D
Brandi aka Help me!
Between my husband and myself: T2i gripped, Canon 7D, EFS 18-135 IS Macro 0.45/1.5ft, EFS 18-55mm IS Macro 0.25/0.8ft, EFS 55-250mm IS Macro 1.1/3.6ft, and 2 nifty fifties.
xarqi
Mar 03, 2012 04:59 |  #2
What is your budget?
What type of macro work?
In any case, look at the EF-S 60/2.8, the EF 100/2.8,or the 100/2.8L.
The Tamron 90 is also well-regarded, and I think there is a Sigma 105 mm.
For less than 1:1 reproduction there is the EF 50/2.5 CM.
Then there are older lenses that could be adapted cheaply, such as the Zuiko 50/3.5.
By the way, both the 18-55 IS and 55-250 IS that you have will get close to 1:3 - would that suffice?
Sirrith
Gallery: 50 photos
Joined Nov 2010
Mar 03, 2012 05:36 |  #3
There's also the sigma 50 2.8 macro which is 1:1 IIRC and is quite cheap, and the tokina 100mm 2.8.
-Tom
Mjolnir
Mar 03, 2012 06:01 |  #4
Ive got the Sigma 150mm F/2.8 OS. Its every bit as awesome as advertized.
www.toeterphotography.​blogspot.com (external link)
Flickr. (external link)
365 project. (external link)
Eos 7D, 300mm F/2.8 L IS, 100-400L, 24-105L, 70-200L II IS USM, Sigma 150mm OS, Sigma 10-20mm, Canon 60mm Macro, Canon 50mm F/1.8.
rick_reno
Mar 03, 2012 10:20 |  #5
The Canon 60mm is excellent and not expensive. The two 100's give you more working room.
worrptangl
Mar 03, 2012 10:29 |  #6
I have a Tamron 90mm. It extends out to 1:1 but the front element is recessed an inch or so which gives it a built in hood so to speak. It's really sharp. I use it for macro only, but the AF is the typical Tamron whine.
They can be bought quite cheap. I got mine for around $300 shipped from here.
EDIT: If you go to the Macro section they have a multitude of threads on this same exact question. https://photography-on-the.net/forum/forumdis​play.php?f=123
Geejay
Gallery: 33 photos
Mar 03, 2012 11:05 |  #7
On a budget a lightly used EF 100mm f2.8 would be a pretty good choice IMO. I've compared one with the EF 100mm f2.8L and from what I could see, there wasn't much in it to be honest..
Both are internal focusing lenses so they don't extend, which I prefer to those that grow substantially.
You can't erase a dream, you can only wake me up.
number ­ six
fully entitled to be jealous
Mar 03, 2012 14:37 |  #8
Geejay wrote in post #14014338 (external link)
The Canon 60 f/2.8 is another that doesn't extend.
It has ring USM focusing which is accurate and fairly fast. And quiet.
Which is good for general purpose shooting, but you probably will want to focus manually for macros.
Speaking of manual focus, my 60 macro has about 180 degrees focus ring rotation from infinity to 1:1, while the rest of my Canon lenses are about 90 degrees or less. This is a Good Thing in a macro lens.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
omer
Gallery: 80 photos
Mar 03, 2012 15:45 as a reply to  @ number six's post |  #9
If you want to play with marco you may want to consider extension tubes
they go for $60-100 and provide excellent way to do macro
My Flickr (old) http://www.flickr.com/​photos/omfoto/ (external link)
R6 | 80D | 7D | M6 |RF24-105 STM|RF35 1.8| EF-S 15-85 |EF 70-300 L |Sig 150-600 C| Sig 10-20 | 50 1.8 |100 2.8 macro|28 F2.8 | efs24| efm 15-45| 270EX | 430EXII |
watt100
Mar 03, 2012 18:03 |  #10
lounroxluv wrote in post #14012945 (external link)
all the macro lens will give you good sharp pics close up, it depends on your budget and features. You can find used deals on the Tamron 90mm 2.8 macro, Canon 100mm macro, Canon 60mm, etc, for $350 or less. You can go cheaper with extension tubes or reversing rings
ejenner
Gallery: 98 photos
Joined Nov 2011
Mar 03, 2012 22:46 |  #11
Mjolnir wrote in post #14013166 (external link)
I just looked at that recently after some comments.
How's the AF? For instance, if I got this lens I would like to also use it for portraits indoors with my 5DII since I don't have a long sub-f4 lens.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
1Tanker
Mar 03, 2012 22:48 |  #12
omer wrote in post #14015911 (external link)
I don't think her husband would be too happy with that! :p
Kel
Gear
NWPhil
Gallery: 13 photos
Mar 03, 2012 23:03 as a reply to  @ 1Tanker's post |  #13
the canon 100mm 2.8 usm can be used for portraits, but you need quite some distance indoors.
I find thebokeh pretty smooth and the pics always sharp.
The 100mm IS 2.8L is great but if you use a tripod all the time for macros and portraits, would be sort of a waste.
You can buy a used 100 2.8usm, a canon 50mm 1.8, plus a ring coupler, a reverse ring for the 50mm, and a set of extensions tubes for less than the 100mm IS costs.
The 50mm can be used for macros with a reverse ring and even with the tubes.
You can join the 50mm on the 100mm end with the coupler, and get even closer/more magnification for macros.
You can use the tubes on either 50 and 100mm and get extra reach.
All this will cost you in IQ, but it would be a very versatile setup
NWPhil
Editing Image OK
GEAR
NWPhil
Gallery: 13 photos
Mar 03, 2012 23:06 |  #14
1Tanker wrote in post #14017870 (external link)
seems they shared the camera gear already anyway - maybe is just one more thing to shared:p
NWPhil
Editing Image OK
GEAR
dfbovey
Joined Mar 2011
Mar 03, 2012 23:10 |  #15
If you're taking handheld shots the 100L with IS is probably the way to go. I did a lot of research and bought one because I'd probably rarely ever use it with a tripod.
Canon 1D markIV - Canon 1D markIII - Canon 6D
Canon EF 16-35mm f/2.8L - Canon EF 24-70mm f/2.8L - Canon EF 70-200mm f/2.8L - Canon EF 100mm f/2.8L Macro IS - Canon EF 400mm f/5.6L - Canon EF 500mm f/4L
4,848 views & 0 likes for this thread, 19 members have posted to it.
What macro lens ?
1662 guests, 160 members online
