Has anybody used the CowboyStudio Meike LCD Viewfinder? If so how is it? Im looking for a cheap but decent LCD viewfinder.. Might even try one of the DIY versions.
WoodworthPhoto Member 241 posts Likes: 1 Joined Feb 2010 Location: Wilmington, NC More info | Mar 05, 2012 17:53 | #1 Has anybody used the CowboyStudio Meike LCD Viewfinder? If so how is it? Im looking for a cheap but decent LCD viewfinder.. Might even try one of the DIY versions. 5D MKii - 7D - Sigma 10-20 - 24-70L - 50mm 1.8 - 70-200L 2.8 IS - 430ex ii - AB1600/vegabond mini -
BustedKnuckles Member 109 posts Likes: 2 Joined Nov 2011 More info | Mar 05, 2012 19:36 | #2 I purchased a eyepiece extender and simply screwed the two together after drilling a small pilot hole and using some small screws from an old computer. If you see me with a wrench - call 911. 5d3, T3i, 17-55 2.8, 50 1.8, 70-200 2.8 L II, 24-105 f4. YN 565, Precision Lupe attached to hacked extended eyecup (no sticky frame) - old enough to have owned an original F-1
RPCrowe Cream of the Crop More info | I use a Hoodman Loup to enable me to view my LCD in bright light. I believe it is just about the same (but a bit more expensive) as the CowboyStudio Meike LCD Viewfinder. It converts the LCD to an eye level viewfinder... See my images at http://rpcrowe.smugmug.com/
IUnknown Senior Member 738 posts Likes: 8 Joined Jun 2007 More info | Mar 06, 2012 15:40 | #4 How about this one> Fiske | Film
Mar 07, 2012 13:26 | #5 Busted Knuckles wrote in post #14031428 I purchased a eyepiece extender and simply screwed the two together after drilling a small pilot hole and using some small screws from an old computer. Slips on and off with no sticky frame mess nor magnets around my magnetic media. Get magic lantern if you don't already and I bet you spend a heck of lot more time using live view Do you have a picture of this? and ya, im going to put magic lantern on. But I notices there is a couple ones on their site. Im not sure which would be best. 5D MKii - 7D - Sigma 10-20 - 24-70L - 50mm 1.8 - 70-200L 2.8 IS - 430ex ii - AB1600/vegabond mini -
Mar 07, 2012 13:28 | #6 Im trying to stay in the $50 range.... any suggestions for ones around that price would be nice. If not, then ill probably make one of the DIY versions. 5D MKii - 7D - Sigma 10-20 - 24-70L - 50mm 1.8 - 70-200L 2.8 IS - 430ex ii - AB1600/vegabond mini -
| Latest registered member is semonsters 983 guests, 108 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
