I shoot 99% RAW and was curious what in-camera setting is recommend? Does it affect RAW images or just jpg? Are there pro's and con's to each? Thanks for any and all replies!
dancinmyazoff Member 187 posts Joined Jun 2008 Location: Long Island, NY More info | Mar 07, 2012 10:58 | #1 I shoot 99% RAW and was curious what in-camera setting is recommend? Does it affect RAW images or just jpg? Are there pro's and con's to each? Thanks for any and all replies! Canon 40D - Canon 50mm F/1.8 - Canon 55-250mm IS - Canon 580ex ii
Mar 07, 2012 11:40 | #2 It only affect .jpeg. Edward Jenner
Mar 07, 2012 12:16 | #3 So would you say Adobe RGB is better when converting RAW to jpg in LR to have prints made up? Canon 40D - Canon 50mm F/1.8 - Canon 55-250mm IS - Canon 580ex ii
HughR Senior Member 999 posts Joined Feb 2011 Location: Toronto, Ontario More info | Mar 07, 2012 13:36 | #4 I only shoot RAW and always have my camera set to AdobeRGB. In Photoshop CS5 I convert to photopro, which I believe is the widest gamut currently available. Hugh
tonylong ...winded More info | Mar 07, 2012 16:15 | #5 When you are shooting Raw, the color space setting will affect the RGB histogram. If you are concerned with shooting "To The Right", it could come in handy since having the camera set to aRGB will give you a little more "room" in the RGB histogram before a particular color gets supposedly clipped -- that is, in sRGB a color could appear to be clipped against the right of the histogram, but with aRGB the histogram will more accurately show the wider range of what the histogram collects). Tony
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Mar 07, 2012 18:01 | #6 dancinmyazoff wrote in post #14043394 So would you say Adobe RGB is better when converting RAW to jpg in LR to have prints made up? No convert to sRGB if you are sending files to a commercial lab. This is for two reasons: Elie / אלי
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Mar 07, 2012 18:10 | #7 tonylong wrote in post #14044941 You can test things out for yourself in your Raw processing software if you have an app that can change your "working color space" -- the Canon software Digital Photo Professional allows you to do this. You can also get this in Adobe Camera Raw (with Photoshop) by changing the Camera Raw Preferences. In Lightroom it's not built in but LR4 does have a "Print Soft Proofing" utility that may provide this. Anyway, if you have an image that is good in aRGB but has clipped colors in sRGB, you should look at that and be prepared to process that image for the Web or other sharing -- pull the colors back a bit before you do a final conversion to sRGB for sharing/printing. LR4's proofing is great. Not only does the histogram change to display the image data in the proofed space, you also have an "out of gamut" alarm that shows exactly what colors are OOG and after making a Proof Virtual Copy you simply adjust that color until the alarm disappears. Elie / אלי
tonylong ...winded More info | Mar 07, 2012 18:54 | #8 tzalman wrote in post #14045670 LR4's proofing is great. Not only does the histogram change to display the image data in the proofed space, you also have an "out of gamut" alarm that shows exactly what colors are OOG and after making a Proof Virtual Copy you simply adjust that color until the alarm disappears. Well, good! Remember all the times we complained about LR not having soft-proofing? Some folks at Adobe actually do listen! I've noticed that with the Lightroom team -- they seem pretty responsive. Tony
Mar 07, 2012 20:01 | #9 tzalman wrote in post #14045621 No convert to sRGB if you are sending files to a commercial lab. Yes, absolutely. This is what they will expect. Edward Jenner
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Mar 07, 2012 22:15 | #10 Since about 2004, over the years I have repeatedly published a challenge, for anyone to mention the name of a commercial photographic printer who can print an aRGB file without first converting that file to sRGB and its narrower profile. Only once, within the past quarter, have I ever had anyone who could list such a commercial lab! IOW, aRGB printing by a commercial photographic print lab is highly unlikely!!! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
HughR Senior Member 999 posts Joined Feb 2011 Location: Toronto, Ontario More info | Mar 08, 2012 14:14 | #11 Wilt wrote in post #14047186 In recent years home printers were introduced which could print the aRGB gamut, but then they are inkjet and not photographic prints. I'm not quite sure what you mean. Many of the best photographic prints in museums today are archival ink jet prints. These are certainly photographic prints by any standards. Hugh
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Mar 08, 2012 14:17 | #12 dancinmyazoff wrote in post #14043394 So would you say Adobe RGB is better when converting RAW to jpg in LR to have prints made up? No. Most commercial printers are set up for sRGB. Skip Douglas
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Mar 08, 2012 15:04 | #13 HughR wrote in post #14050845 I'm not quite sure what you mean. Many of the best photographic prints in museums today are archival ink jet prints. These are certainly photographic prints by any standards. What I meant by 'photographic' is optically created prints on light sensitive emulsion. These do not have undesirable characteristics like black ink pigments which sit on top of the coating, or metamerism, or running of dyes when wet with water. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
RichSoansPhotos Cream of the Crop 5,981 posts Likes: 44 Joined Aug 2007 Location: London, UK More info | Mar 08, 2012 15:14 | #14 Permanent banI'm reliably told that if you shoot sRGB you can't then expect to get the full colour gamut if you convert it to AdobeRGB pp, so hence, if you're expecting to get prints from your photography, shoot AdobeRGB convert to sRGB if you want to upload to the web, that way you haven't lost your full range of colour gamut.
HughR Senior Member 999 posts Joined Feb 2011 Location: Toronto, Ontario More info | Mar 08, 2012 15:16 | #15 Wilt wrote in post #14051219 What I meant by 'photographic' is optically created prints on light sensitive emulsion. These do not have undesirable characteristics like black ink pigments which sit on top of the coating, or metamerism, or running of dyes when wet with water. That's true. However, modern inkjet printers have very little problem with metamerism any more, and it is claimed that their longevity before fading outlasts silver prints. Some of the best museums in the world collect archival inkjet prints, including the International Center of Photography in New York City. I've been making inkjet prints for 5 years and have never smeared one with water or seen any degradation of the images. Hugh
| Latest registered member is ealarcon 1006 guests, 171 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
