Thread started 25 Nov 2005 (Friday) 15:31
Are coated filters worth the extra money?
JohnCollins
Joined Nov 2005
Nov 25, 2005 15:31 |  #1
I just ordered a Canon EF 50mm f/1.4 USM and the lens hood (I get hoods for every lens) and B&W UV filter. I found out later they make a higher-cost model coated to combat lens flare.
The 50mm f/1.4 isn't a cheap lens, and I'll gladly return my filter and upgrade if it makes any difference. If I use the hood, though I'm wondering if it really matters.
Thoughts, anyone?
John
Jon
Joined Jun 2004
Nov 25, 2005 16:22 |  #2
If you use a filter, you should use a good multi-coated one. Never know when there'll be some stray light wanting to bounce around off uncoated glass.
Jon
Cocker Spaniels
snibbetsj
Joined Jun 2004
Nov 25, 2005 18:47 as a reply to  @ Jon's post |  #3
Good multi-coated filters, such as B&W or Hoya, will help reduce CA, lens flare, and generally produce a better photo in the conditions which may cause CA, etc. A good many folks, myself included, don't use the UV/Skylight filters as the lens, especially with the proper hood, are normally themselves multi-coated to reduce these phenomena. Although circular polarizers/graduated ND and ND filters are widely used because there effects are difficult to impossible to reproduce in PS.
Jeff Stebbins
Tsmith
Formerly known as Bluedog_XT
Nov 25, 2005 19:08 |  #4
Yes
Luckie8
Nov 25, 2005 22:41 |  #5
Multi Coated filters are highly recommended!
Feedback
dgcorner
Nov 25, 2005 23:17 |  #6
John,
Yes, the multi-coated filters make a difference. But if you were to purchase a single filter I would go for a polarizer IMHO. As Jeff says, it is difficult to reproduce certain effects on PS.
Cheers!
John
John;)
Believe... Work hard... and it will happen!
malla1962
Joined Jul 2004
Nov 26, 2005 04:32 as a reply to  @ dgcorner's post |  #7
Yes.:D
foxbat
Joined Jan 2005
Nov 26, 2005 04:55 |  #8
B&W are good quality so I don't think you made a mistake. Take a shot with and without the filter when you get it. I'll bet you can't tell the difference.
Andy Brown; South-east England. Canon, Sigma, Leica, Zeiss all on Canon DSLRs. My hacking blog (external link).
1,490 views & 0 likes for this thread, 8 members have posted to it.
1364 guests, 175 members online
