I swore I was done with the 85L, but I came up with a new need for this lens and so now I have a 'UZ' version of the 85L II.
I put it on my 1D4 and took a few shots. All were awful, clearly backfocused by a huge degree.
So I set up a test and dialed in the 1D4....negative 17 on the MA got the lens right. I took a bunch of handheld shots afterwards and the lens is hitting just fine. So MA to the rescue, right?
But I also have a 5Dc. Is this lens going to be usable at all on my old body that lacks MA? I mounted the lens and checked.....it nails focus every time. In fact, the 85L II is more consistent on my 5Dc than it is on the microadjusted 1D4.
This isn't the first time I've run into this either. My 50L needed a lot of MA to work on the 1D4, but it is perfect on the 5Dc.
And the problem isn't that the 1D4 is always wrong in one direction. Sometimes it needs negative MA, sometimes positive.
How can this make sense? Why do all my lenses work just fine on the body that does not allow for MA, but they really need MA on the other?
