FORUMS Photography Talk by Genre Critique Corner
Thread started 10 Mar 2012 (Saturday) 22:39
Another water bubble shot and question
nate42nd
Mar 10, 2012 22:39 |  #1
Glass with water drops 8 inches above white plate with coins.
Canon 100mm lens
1/200 Second
ISO 320
F/6.3
Flash : 430 EXii at 1/64 power no diffusion on the same level as the background 24 inches away pointed directly at the plate with the coins (Triggered by Cactus V4 wireless system) at the 2 o'clock position.
What do you think of the shot? How do I get the background to be in focus inside the bubbles? More or less distance between water and background? Focus on the reflection and not the bubbles themselves? Thanks.
IMAGE: http://farm8.staticflickr.com/7058/6971184821_21ef3e11d9.jpg
IMAGE LINK: http://www.flickr.com/​photos/nate42nd/697118​4821/  (external link)
Water Bubbles B&W (external link) by nate42nd (external link), on Flickr
Here's one with a much smaller aperture. That and the distance between glass and background are they keys. The candy on the white plate is more in focus with the smaller aperture.
IMAGE: http://farm8.staticflickr.com/7053/6827909356_3377a66977.jpg
IMAGE LINK: http://www.flickr.com/​photos/nate42nd/682790​9356/  (external link)
Bubbles and Candy (external link) by nate42nd (external link), on Flickr
7D - - 17-55 F/2.8 - 24-105 F/4L - 100mm F/2.8 - 50mm F/1.8 - S95 / To see all click here
My Flickr (external link)
Pixil ­ Studio
Joined Feb 2012
Mar 12, 2012 00:32 |  #2
kewl shots
Denver wedding and event photographer (external link)
My photography Blog (external link)
OrangeImaging
Joined Nov 2011
Mar 12, 2012 00:35 |  #3
love the first. colors are too dull in second
Gear
Titus213
Mar 12, 2012 13:00 |  #4
I believe you should be focusing on the reflection....
That second image shows some real promise.
Dave
Perspiring photographer.
nate42nd
Mar 12, 2012 18:18 |  #5
Pixil Studio wrote in post #14070196 (external link)
kewl shots
OrangeImaging wrote in post #14070211 (external link)
Thanks for the comments. I think I got the hang of it. A smaller aperture and a little more distance between the glass and the background seems to work.
Titus213 wrote in post #14072590 (external link)
Thanks....i think you are right. Thanks again for the comment.
drvnbysound
Mar 12, 2012 18:46 |  #6
I did one of these a few weeks ago using Reese's pieces as the background. I believe most of the how-to images were shown using a macro lens. I don't own one, so I decided to try it with my 50 f/1.8 instead. I manually focused, as auto-focus had a hard time focusing on the transparent water droplets and usually locking onto the candy instead. Exif data is intact, which show's I shot it at f/8. As much as I wiped down the table before hand, I am not sure how or where all the dust and specs came from but they are present nonetheless :(
2775
x
2775
TOO LARGE!
EMBED PREVENTED, IMAGE TOO LARGE:
http://img35.imageshac​k.us/img35/3379/img605​1cropped.jpg
Click here to see our image rules.
I use manual exposure settings on the copy machine
..::Gear Listing::.. --==Feedback==--
...A few umbrella brackets I own...
nate42nd
Mar 12, 2012 18:54 |  #7
That's a well done shot especially not having the advantages of a macro. Manual focus is needed. I never use AF with my macro lens.
I used "Rain-X" on my glass. It's used for car windshields so the rain will not stick.
Titus213
Mar 12, 2012 19:23 |  #8
Put a face under the glass - https://photography-on-the.net …/showthread.php​?t=1049171
Dave
drvnbysound
Mar 12, 2012 22:51 |  #9
nate42nd wrote in post #14074561 (external link)
Thanks. Yeah, I did use Rain-X, which involved initially cleaning the glass, applying the Rain-X, removing the Rain-X haze by wiping it again, then re-cleaning the glass again. I also needed to spray a few times to get the drops of water the way I wanted them... After all that wiping of the glass, I was really surprised to see all the specs and particles still on the glass when it was said and done. You can't see them nearly as well on the low-res image I posted (though you certainly still can) but they are certainly more prevalent in the high-res version. :( Ohh well, I really only shot a few exposures of it; primarily wanting to attempt doing it just because I thought it looked neat. I'm sure I'll probably do it again later with something else down there... maybe I'll shoot tethered and make sure it's spotless next time :)
nate42nd
Mar 12, 2012 22:56 |  #10
drvnbysound wrote in post #14075888 (external link)
It looks great. Just use the spot removal tool in Picasa, Lightroom, etc.... to remove the little specs. I did that with some of mine. It can help a lot. FYI I shoot RAW. If you don't.....I would give it a try. It makes all this a lot better with no loss of IQ.
chauncey
Mar 13, 2012 07:05 as a reply to  @ nate42nd's post |  #11
You cannot get the entire water droplet in focus with a single exposure, while maintaining adequate image size, as DOF is a limiting factor. Spend some time using "focus stacking" techniques.
nate42nd
Mar 13, 2012 15:53 |  #12
chauncey wrote in post #14077239 (external link)
Focus stacking would be the best way to make one of these look good. Good tip!
1,851 views & 0 likes for this thread
Latest registered member is toyotatoyope
1870 guests, 279 members online
