Thread started 11 Mar 2012 (Sunday) 14:24
SanDisk CF 16GB Extreme 60MB/s not recognized/not doing good things
JonK
Joined Feb 2004
Mar 11, 2012 14:24 |  #1
Hi all,
So today I went to pop my 16GB SanDisk Extreme CF in and, well, good things did not happen. Windows said the disk was blah blah and could continue and scan and fix issues, ok. So I did that. Then nothing opened. Fortunately there wasn't anything on the card worth much. I said ha! I got this! I popped it into my 5DII and went to format is, and no dice - when the car is in the camera and the camera turned on the red LED on the camera comes on but nothing comes up. If I remove the card and restart the camera the camera works fine with other cards. So then I tried to format the card from within Windows 7 - I got a "windows cannot format the card..." type message.
Now, when I insert the card into my PC it's not seen at all.
Any ideas? SanDisk has a lifetime warranty on this card but it'd be nice if I didn't have to go through all that.
Thanks,
Jon
7NE | 7D | 5DII | 16-35/2.8L II | 24/1.4L II | TS-E 24/3.5L II | 50/1.4 | 85/1.2L II | 100/2.8L IS | 70-200/2.8L IS II | 400/5.6L | PIXMA Pro 9500 Mark II
check my blog:
www.jonkensy.com (external link)
Euro852
Joined Nov 2011
Mar 11, 2012 14:46 |  #2
You should contact SanDisk customer support they are really helpful. I have two of the 16GB Extreme.
It looks like they have a hotline for Extreme memory cards. or 1-866-SANDISK (726-3475)
Extreme Memory cards 1-866-270-5532. I'm lucky, their HQ is in my area.
http://www.sandisk.com …campaign=HomePa​geTracking (external link)
Main Camera: FUJiFILM X-E2 | 18-55mm
Secondary: Canon 5DMKII | 500D Gripped | 24-105mm F4 L | EF-S Lenses | 580EX II | Feisol 3441S / Manfrotto 496RC2
JonK
Joined Feb 2004
Mar 11, 2012 14:47 |  #3
Thanks I guess I will have to do that :(
check my blog:
jtalerico
Mar 11, 2012 16:25 |  #4
See if this helps.
http://kb.sandisk.com …detail/a_id/107​/kw/format (external link)
Website (external link) 7D | 70-200 2.8 IS L | 10-20 F3.5 SLD | 17-50 F2.8 EX FLD | 580EX II | BG-E7 | Bogen legs & Bogen 3265 Head | ThinkTank UD60 | Lowpro 302AW
JonK
Joined Feb 2004
Mar 11, 2012 16:53 |  #5
Unfortunately the disk doesn't show up in Disk Management :(
check my blog:
jtalerico
Mar 11, 2012 17:37 |  #6
Yikes!
Have a Mac/Linux machine to see if that recognizes it? Possible issue with the CF reader (unless you can read other CF cards).
JonK
Joined Feb 2004
Mar 12, 2012 08:59 |  #7
Linux machine sees the disk, sees the file/folder on it, but as soon as I try to open a folder or format the disk I get an i/o error
check my blog:
jtalerico
Mar 12, 2012 09:32 |  #8
Have you tried dd?
sudo dd if=/dev/zero of=/dev/hda
This will just write a bunch of zeros to the card.
JonK
Joined Feb 2004
Mar 12, 2012 10:10 |  #9
I just did
dd if=/dev/zero of=/dev/sdc1 (careful writing hda there, someone may not understand and format their hard drive lol)
it looked like it wasn't doing anything so I did CTRL+C, then I saw that it had written 896MB blah blah for 2 minutes, at 16.xxMB/S.... so, now I am going to try again and let it run until it finishes.
I did dd if=/dev/zero of=/dev/sdc and got an i/o error, but when I did sdc1 it seems to go - not sure if its just syntax at that point or what.
check my blog:
jtalerico
Mar 12, 2012 10:13 |  #10
Make sure you unmount the device before writing the zeros.
Yup, it takes some time to do dd.
Feel free to hit me up on gtalk if you have on the spot questions, I will PM you my contact.
JonK
Joined Feb 2004
Mar 12, 2012 12:41 |  #11
Thanks -
Called SanDisk and they're replacing.
check my blog:
jtalerico
Mar 12, 2012 12:53 |  #12
lol, sounds like you have exhausted all other methods!
Glad to hear they resolved it!
5,025 views & 0 likes for this thread, 3 members have posted to it.
1053 guests, 104 members online
