Thread started 11 Mar 2012 (Sunday) 15:35
Remote shutter & 5D MK II HELP !!!!
Hollywoodgt
Joined Mar 2011
Mar 11, 2012 15:35 |  #1
I have a SMDV RFN3- Rx and it has the N style plug that goes in the side of the 5D MKII but it will not trigger the shutter. I set the camera to bulb mode and turn the device on. There's a blue light on the receiver and a light on the transmitter and it's interrupted when I press the remote shutter button. It won't trigger the shutter.
I've looked on You tube man can find them being sold but no directions. Any help would be greatly appreciated.
www.Jeffreyantonphotog​raphy.com (external link) http://www.modelmayhem​.com/jeffreyanton (external link)
Bodies:5D Infared 5D MK II/5D MKIII 4 Travellites 750R
18=55mm/55-250mm/50mm Ef1.8/70-200 ef2.8L IS II/85mm 1.2L II/24-70mm 2.8L II/16-35mm 2.8L II 2X Ext II
(3) 430EX/(3) remotes/2umbrellas plus assortment of defusers
RandyS
Mar 11, 2012 16:04 |  #2
This is far more a WAG than it is anything else.
I was reading another thread on remotes some time over the past several days, and one guy mentioned in passing that the remote they were talking about didn't work if focus was set to the back button. I don't know if he meant he couldn't focus from the remote, or if he couldn't trigger the shutter.
Jon
Joined Jun 2004
Mar 11, 2012 16:08 |  #3
The N3 connector's very fussy. Your remote may not be making good contact when inserted. Try wiggling it down in there. This can be a problem with third-party remotes since they have to make their own N3, and some get the depth wrong. Not saying it's the issue in your case, but some people have shaved a very little bit of the plastic off the tip of the N3 plug to get a better fit/contact.
Jon
Cocker Spaniels
Hollywoodgt
Joined Mar 2011
Mar 11, 2012 16:30 as a reply to  @ Jon's post |  #4
Interesting I'm surprised you can't find more on the remote shutter. Looks like a fairly easy trigger, but I'm flying in the dark with no directions.
Thank you much in advance for your replies
Jon
Joined Jun 2004
Mar 11, 2012 16:57 |  #5
How about a link to the one you got? Radio remotes pretty straight-forward as long as both transmitter and receiver are set to the same channel. Most receivers I've seen also have a button that lets them function as a wired release. Tried pushing that? But like I said, the problem's usually that the plug's not making contact with the pins in the camera's N3 socket.
Jon
Cocker Spaniels
Hollywoodgt
Joined Mar 2011
Mar 11, 2012 17:11 as a reply to  @ Jon's post |  #6
Took the unit back out. Made sure the plug and the pins were in the right direction. Made sure the transmitter was set to bulb...rodger that....camera bulb setting yep. Wiggle plug notta zip nothing. The connections on this one appear to be right on the edge
RichSoansPhotos
Mar 11, 2012 17:16 |  #7
I thought it was supposed to be the N3+ connector
Hollywoodgt
Joined Mar 2011
Mar 11, 2012 17:44 |  #8
400dabuser wrote in post #14068123 (external link)
You got me now ...it fits in the connection I have. Need to find if this is the correct model for a 5D MKII
Jon
Joined Jun 2004
Mar 11, 2012 18:51 |  #9
If it says it's for an N3 connector, it should function correctly. However, as I said before, the N3 connector is a Canon proprietary connector. Any third-party makers are trying to approximate it, and may not get it right in all cases. That leaves you trouble-shooting it. Does your release have a separate button on the receiver? If it does, try using that to trip the camera. And make sure that AF is set to the shutter button as RandyS said. If you use CF to separate AF from the shutter button, expect problems with a remote.
Jon
Cocker Spaniels
Hollywoodgt
Joined Mar 2011
Apr 02, 2012 14:25 as a reply to  @ Jon's post |  #10
Sorry guys....had sopme pressing issues. Yes it is the N3 connector and it was set to buld and you can see the light showing the remote is triggering the slave, but doesn't trigger the camera. I did not change the camera settings though...something about a/f settings. Maybe that's it?
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Apr 02, 2012 14:29 |  #11
Is the lens set to manual focus? The camera won't fire if it can't confirm focus. If you've covered this ground already then ignore me, but you have to eliminate the obvious, and lack of focus is the first thing that will stop it from shooting.
edit: my point about setting the lens to manual focus is that when the lens is set to manual focus the camera will fire regardless of whether it has focus confirmation.
500px (external link)
1x (external link)
instagram (external link)
Hollywoodgt
Joined Mar 2011
Apr 08, 2012 12:54 as a reply to  @ Scatterbrained's post |  #12
Ok so I went back at the remote. remote plugged in and trigger light shows it working. Lens set to MF and nothing. Then I started wiggling the plug and the camera tripped? If I press it in it may fire the shutter 2-3 time. At one point I switched the remote connected to the camera out of bulb function.......then it triggered a few times and stopped working.
My conclusion is that the SMDV remote trigger connector maybe bad? So tomorrow I'll head to Calumet and get a Canon one.
Thanks again for your replies
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Apr 08, 2012 13:04 |  #13
Just an FYI, I've been using the Vivitar unit from Amazon and it's been pretty reliable. The only issues I've had are how it will misbehave when the battery gets a bit low. It will trip the shutter and not release it, so it just keeps firing until you unplug it. That's when you know it's time to replace the battery. :)
http://www.amazon.com …TF8&qid=1333908​265&sr=8-3 (external link)
1x (external link)
Hollywoodgt
Joined Mar 2011
Apr 10, 2012 23:20 |  #14
Scatterbrained wrote in post #14230650 (external link)
Interesting because when I did get it to shoot, it would shoot off like 5-10 pics. I thought I checked that battery....weird things is when you bush on the connector at the camera it fires it???
5,257 views & 0 likes for this thread, 5 members have posted to it.
1402 guests, 100 members online
