Thread started 12 Mar 2012 (Monday) 12:08
Extention tubes for my 400mm f5.6?
Allan.L
Mar 12, 2012 12:08 |  #1
Can you fill the frame with lets say, a chickadee with this lens or is the MFD too far? For those that use them, how many mm of tubes do you use and for what? (bugs, birds etc) Does adding them affect infinity focus too? **Edit, i see they will indeed limit max focus distance!
Thanks in advance!
Billginthekeys
Billy the kid
Joined Nov 2005
Mar 12, 2012 12:15 |  #2
Yes adding an extention tube will eliminate infinity focus. The 400 5.6 is a great lens, and it is capable of getting close enough to most birds, but it's strength is for birds in flight, where its long MFD actually helps by minimizing focus searching. If you feel for your particular application being closer is more important than maximum reach, the 300 F4 IS is capable of much closer focus distances.
Mr. the Kid.
Go Canes!
My Gallery (external link)My Gear
what the L. just go for it.
Allan.L
Mar 12, 2012 13:04 |  #3
Just did some tests with my sigma at ~400mm and at 3.5m it definitely works for me (chickadee size subject).
Billginthekeys
Billy the kid
Joined Nov 2005
Mar 12, 2012 13:17 |  #4
Well you certainly can fill the frame with a small subject, here is a woodpecker of mine taken with the 400 5.6:
http://www.pbase.com …hotography/imag​e/79262046 (external link)
and an osprey portrait:
http://www.pbase.com …hotography/imag​e/68883479 (external link)
It has always been close enough for me.
Mr. the Kid.
Go Canes!
Allan.L
Mar 12, 2012 13:28 |  #5
Great shots, looks like it will work for me! Just wanted to make sure... Thanks!
Mile ­ High
Joined Jun 2011
Mar 12, 2012 13:42 |  #6
You can't fill the frame without tubes, but with a little cropping you can. Adding an extension tube limits your focus range and leaves you with a very shallow depth of field. For example adding the ET-25, your focus range will be limited to 8ft to about 21.5ft and your DoF wide open at 8ft will be 0.02 inches. So for birds I use the bare lens and add a tube for insects (stopped down with tripod) or portraits.
http://www.flickr.com/​photos/marco_5280/6968​427229/ (external link)
BufordFZ1
Joined Oct 2011
Mar 12, 2012 13:44 as a reply to  @ Mile High's post |  #7
Billy, what was your distance from the Woodpecker?
A2, 60D, 5DII
Canon EF 17-40mm L
EF 100mm L
Canon EF 70-200mm f/2.8L
Canon EF 400mm f/5.6L USM,Canon 50 1.4, 430 EXII,580 EXII
Billginthekeys
Billy the kid
Joined Nov 2005
Mar 12, 2012 13:53 |  #8
BufordFZ1 wrote in post #14072923 (external link)
That was years ago, but I know exactly where it was taken, I am going to say, 20' probably.
Mr. the Kid.
Go Canes!
bobbyz
Mar 12, 2012 14:46 |  #9
Get a set of kenko tubes and you will be happy. Now bird never come so close to me, only happened twice, once was baby swallow where I needed all three tubes on my 500mm f4 as it was so close I could touch it. Second time was a little shorebird who come so close as I was lying in the nud for more than an hr. But no tubes with me that day.
IMAGE: http://www.bobbyzphotography.com/img/s11/v3/p603602627-5.jpg
Fuji XT-1, 18-55mm
Billginthekeys
Billy the kid
Joined Nov 2005
Mar 12, 2012 14:55 |  #10
Great Shot!
Mr. the Kid.
Go Canes!
Allan.L
Mar 12, 2012 15:13 |  #11
Awesome shot! I might just get the tubes anyways...
phreeky
Mar 12, 2012 17:01 |  #12
The tubes are worth owning generally, but keep in mind that the longer the lens the more extension is needed to have a significant effect.
1,674 views & 0 likes for this thread, 6 members have posted to it.
1077 guests, 115 members online
