I did some searching but couldn't find what I was looking for. So I figured I would ask the masses to help me out.
I have a 550D and like to use neck/shoulder strap and a hand strap. I was hoping to find a strap that can convert from neck strap to hand strap. I've seen how some use both at the same time with camadapter and such. I came up with an idea and was wondering if it exists. So is there a neck/shoulder strap that connects to the tripod screw and the right side of the camera, which has clips to disconnect a portion of the strap then those to clips will connect with to each other and become a hand strap. There could also be a second pad on part of the strap to make it basically exactly like a hand strap. I hope that makes sense. Sorry if it doesn't. My other idea is basically the same but instead of disconnecting the strap can be clipped to the bottom on the short side and the rest would just dangle underneath the bottom of the camera.
If this doesn't exist can somebody recommend a good neck strap (not to bulky) that has high quality clips that can be disconnect that dont leave much extra strap hanging on the camera. Thanks for the help.
