Can anyone suggest a good setting to use when scanning 5x7 inch prints for archiving purposes? My scanner has dpi settings from 50-12800. I know the higher the better but may no be practicle size wise. .... Thanks
sagebrush Member 158 posts Joined Dec 2001 More info | Nov 26, 2005 10:49 | #1 Can anyone suggest a good setting to use when scanning 5x7 inch prints for archiving purposes? My scanner has dpi settings from 50-12800. I know the higher the better but may no be practicle size wise. .... Thanks
Mark_Cohran Cream of the Crop More info | Nov 26, 2005 10:54 | #2 I don't know what others do, but I set my scanner to its maximum optical resolution (not the interpolated value). That way I know I'm getting the maximum physical resolution I can from the scanner. This normally results in a large file, but since this is an archive, I burn them to DVD anyway. Mark
My scanner is an Epson 2400 Photo. The manual shows optical res = 2400 x 4800. I guess I'll use 2400 dpi and save as TIFF.
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | Wow, 2400 DPI!
mbellot "My dog ate my title" 3,365 posts Likes: 20 Joined Jul 2005 Location: The Miami of Canada - Chicago! More info | The approximate "resolution" of a standard photo is approximately 200 - 300 dpi, so scanning at a much higher resolution is generally pointless and only results in larger files. The one exception is if you are trying to enlarge a photo, then having the extra "redundant" data can be helpful.
Ya, I couldn't get to 2400 and even at 1600dpi my file size was 745 Mb! Looks like 300dpi will work fine and at way less files size.
Hellashot Goldmember 4,617 posts Likes: 2 Joined Sep 2004 Location: USA More info | Nov 26, 2005 21:13 | #7 Permanent bansagebrush wrote: Can anyone suggest a good setting to use when scanning 5x7 inch prints for archiving purposes? My scanner has dpi settings from 50-12800. I know the higher the better but may no be practicle size wise. .... Thanks I'm guessing that your 12800 is an "interopolated" resolution and not optical. Basically like the horrible "digital zoom" in dP&S cameras. You should stay within your optical resolution range. 5D, Drebel, EOS-3, K1000
| Latest registered member is Mihai Bucur 1210 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
