Thread started 13 Mar 2012 (Tuesday) 12:31
Some news about the future version of DPP and the 5D Mark III
yb98
Joined Feb 2003
Mar 13, 2012 12:31 |  #1
AH: What new improvements are offered in the new Canon DPP software in combination with EOS 5D Mark III?
CW: We targeted three new features for the new version of DPP that will be released together with the EOS 5D Mark III:
· Support for the 5D Mark III’s HDR mode.
· Support for the Multiple Exposure mode of the 5D Mark III and EOS-1D X.
· A new feature called Digital Lens Optimizer processes RAW images to achieve ideal optical characteristics for all types of optical aberration or diffraction, effects of a low-pass filter in front of a CMOS sensor, etc. This function improves image quality particularly in the image periphery in addition to the image center. This function is made possible because the entire design-through-manufacture process, for camera, CMOS sensor, EF lens, and DPP, is carried out entirely at Canon. Images are processed optimally using lens information in the image files (focal length, subject distance, and aperture) and lens data specially for the Digital Lens Optimizer. (However, the size of a .CR2 file will be two to three times larger after applying the Digital Lens Optimizer.) Adjustments are made for such aspects as spherical aberration, chromatic aberration, astigmatism, curvature of field, sagittal halo, chromatic aberration of magnification, axial chromatic aberration, diffraction, and the effects of a low-pass filter in front of the CMOS sensor. DPP’s Digital Lens Optimizer will be usable with any of 29 compatible lenses initially. It works with .CR2 files from EOS models released since 2006 (EOS 30D and forward).
Extracted from an interview with Chuck Westfall (external link), technical advisor at the Professional Engineering & Solutions Division, Canon U.S.A. Inc.
Best DPP Threads
DPP++ Video Channel (external link)
New Version DPP++ 11.3 released (external link)
brose
Joined Feb 2012
Mar 13, 2012 18:15 |  #2
yb98 wrote in post #14078694 (external link)
Interesting. Thanks for posting.
All these corrections are post capture, and so are pixel manipulations. They are not optical adjustments. So I fear greatly for resultant IQ. For example, from multiple software sharpening as in correction of AA filter, RAW presharpening, sharpening several times in PP as is usual - all of this will come to an ugly end!:(
Neil
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Mar 13, 2012 18:18 |  #3
My question is does it rewrite the CR2 file of convert it? I also noticed that little tidbit but when he says the .CR2 file will increase in size as a result of the DLO I wonder if it will really rewrite the raw file or if it will convert it to TIFF or some such.
500px (external link)
1x (external link)
instagram (external link)
Saxi
Mar 13, 2012 18:22 |  #4
I hope Lightroom is able to mimic this type of functionality. I do not want to run files through DPP and I don't want 3x the file size either. Will test both once I get my hands on it.
5D III, 24-105mm f/4 L, 135mm f/2 L, 70-200mm f/4 IS L, 580EX II
Full Gear List
Flickr Photostream (external link)
DavidWatts
Gallery: 128 photos
Mar 13, 2012 21:05 |  #5
Why would RAW files be so ridiculously large with this feature enabled? And is Chuck referring to RAW files coming out of the camera, or re-written RAW files out of DPP? I am hoping it is the later. Would one enable DLO in the camera menu?
My Smugmug site (external link)
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Mar 13, 2012 21:08 |  #6
DavidWatts wrote in post #14081878 (external link)
DLO, as I understand it, will be a function of DPP (hence it's working with all cameras from the 30D on up).
1x (external link)
DavidWatts
Gallery: 128 photos
Mar 13, 2012 21:25 |  #7
OK, that helps, and makes sense. My 40D with Canon glass could benefit it seems. But let's say I have a 10MB .CR2 file from my 40D and a 23MB .CR2 from my 5DIII. All I want to do is output a JPEG from (future) DPP from the RAW files I shoot in either camera. My original .CR2's should not change, right? But if I re-save that .CR2 file with DLO settings as a new .CR2 file, that resultant file would become humongous? Is this your understanding?
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Mar 13, 2012 21:41 |  #8
DavidWatts wrote in post #14081998 (external link)
I was actually planning on emailing Canon to find out if it outputs a new CR2 or a Tiff file, it sounds like a new CR2 but I want to be sure.
1x (external link)
tonylong
...winded
Gallery: 60 photos
Mar 13, 2012 21:42 |  #9
I don't know what CW was referring to in the original post when he talked about that function and the Raw files being maybe tripled in size, but it would have to be an in-camera setting. DPP does not save processed .CR2 files in that sense.
I'd say we will have to wait and see as far as how these new processes will work with other cameras -- too little info in that comment to make an educated guess!
Tony
Saxi
Mar 13, 2012 21:47 |  #10
tonylong wrote in post #14082144 (external link)
I think it is a new version of DPP that would. Either way, it sounds like a big PITA workflow.
Full Gear List
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Mar 13, 2012 21:56 |  #11
Digital Lens Optimization is a function available in the new DPP release.
1x (external link)
woos
Mar 13, 2012 22:01 |  #12
I guess we'll know in a week or so when someone gets their 5d3 and posts the new version of dpp online.
amanathia.zenfolio.com
brose
Joined Feb 2012
Mar 13, 2012 22:32 |  #13
No, the original RAW file cannot change, it is the full set of data delivered from the camera. Any digital file will "benefit" from pixel manipulation, that's no mystery! And something else that's not a mystery is that when pixel manipulation adds data the file size increases! This will happen on conversion. Thus my gripe, that this kind of thing adds more and more software hoops for the RAW optical information to contort its way through. That does not seem like "progress" to me, at least not in a photographic sense. In a graphic illustration sense, maybe...
Neil
tzalman
Fatal attraction.
Mar 14, 2012 05:02 |  #14
brose wrote in post #14082461 (external link)
Neil
Your statement, "the original RAW file cannot change", should be, "the original RAW image data cannot change". DPP already changes CR2 files by inserting new editing instructions into the metadata alongside the instructions from the camera. This is something only DPP can do because the Canon designers know CR2 code, but DPP has always done it. You have the option today in the File menu of Save, which writes the metadata to the original, or Save As, which writes a copy CR2 with the new metadata. However, this adds only a few KB, so the statement that the DLO metadata will be huge is very strange. If the DLO data is in DPP (presumably, a profile for every supported lens/camera combination) why would the file need to contain anything more than a few lines of code saying, in effect, "Do DLO!" My money is on Westphal having made a mistake and meant to say the DPP itself will be bloated by the additional data.
We have just seen a similar occurrence in Lightroom with LR4 being three times the size of LR3 because of new features (book design and GPS).
Elie / אלי
brose
Joined Feb 2012
Mar 14, 2012 06:04 |  #15
tzalman wrote in post #14083538 (external link)
Yes! That is precisely my meaning!
Thanks for making the clarification!
Neil
35,719 views & 0 likes for this thread, 19 members have posted to it.
1582 guests, 138 members online
