EL_PIC wrote in post #14084387
You should test shoot with another camera same lens and another lenes same camera.
If you dont have the hardware - try friends or a store.
Could be a dead Lens Focus motor ...
This is the surest way to find out what's going on...
There are AF related bits in both camera and lens, that can go bad or wear out. So you have to test both separately...
See if similar problem occurs with other lenses on your 20D.
See if the same problem occurs with the lens on another EOS body.
It's unlikely that a mirror would be dirty enought to interfere with AF and not be very noticeable... but wouldn't hurt to use a rocket blower to puff away any dust on the mirror or elsewhere in the mirror box.
More likely, the electronic contacts between lens and camera are fouled with something, interrupting communication between the camera and lens. Use a clean rag dampened slightly with isopropyl (rubbing) alcohol to wipe the electronic contacts on the rear of the lens as well as the matching contacts just inside the bayonet mount on the camera. Just be very careful to not touch the mirror or optics.
If that doesn't help, you might try rebooting the camera. To do that, remove all the batteries including the little silver memory battery, then let the camera sit for an hour turned on. Or for more immediate drain of remaining power press the shutter release button once... camera won't fire without any batteries, this just drains any remaining power in the camera. This works with some models, not sure if 20D is one of them or not.
Reinstall the batteries, check the time/date. If you got a proper reboot, they should need to be reset. If not, try again.
Another thing you can try is reloading the camera's firmware. It's possible that it's gotten corrupted or something. You should be able to get fresh copy of it at the Canon website. Just follow the instructions there carefully.
All these things may or may not help... But they are free or nearly so, and easy to try. If they don't resolve the problem, I'm afraid the camera and lens (unless you've narrowed it down to just the camera or the lens by testing each with other gear) will need to go in for service.
With an older camera and lens that's out of warranty, if there's a good camera repair shop in your area you might take it to them. Otherwise, you may need to send it in to Canon Service Dept.
