Try not to get too caught up in the "sharpness" and "pixel peeping" mindset, as well as the "focusing one-third in" (it doesn't always work). Another consideration that will affect sharpness is "noise", which can be caused by both overexposure and underexposure. Also, what is your sharpening method? How much is applied and when its applied will have a lot to do with the final look of an image.
When doing edits, I'll usually make them at 50% magnification. To check how things look, I'll zoom out to 25% magnification (25% will approximate what you'll see in a print and would be a good indicator to use). Also, when you have close foreground elements in the frame (such as the rocks in your examples), shooting hyperfocally will be a better option.
Instead of overall sharpening the final image, this should be done in stages during the PP process. Generally, after making initial adjustments in LR (exposure, WB), I'll import into PS for the remainder of the work. My first step in sharpening is to apply a mild "capture sharpen" to counteract the AA filter. Then, if certain areas of the image need a tweak, I'll do a "creative sharpening" adjustment (if not, I'll skip this part). Final sharpening, known as "output sharpening", should not be performed until (1) the image has been set to its final dimensions (whether you resize or not) and (2) is based on the image destination (print, type of print method, web publishing, etc). How it will be used will determine the sharpening amount.
This sounds like a lot to take in, but there's a plug-in called "Photokit Sharpener" that already has these various sharpening algorithms pre-set. Its very simple to use, and is also somewhat inexpensive. First thing, though, is to make sure that you have a properly exposed image to start with.
Also, as I mentioned above, with shots that include distant objects as you have here, you're also contending with atmospheric elements such as airborne dust and moisture that will reduce contrast and sharpness...not a whole lot that you can about this (a CPL can only do so much). Bottom line is...be mindful of the conditions that you are shooting in.
