Thread started 14 Mar 2012 (Wednesday) 19:50
A little note about microadjustment.
JakAHearts
Mar 14, 2012 19:50 |  #1
I know people have varied opinions on certain brands of lenses and even canon lenses in relation to their need for micro adjustment. Well, here are some odd facts. I own two camera bodies, a 5DII and a T1i. I also own 3 lenses, a sigma 50 1.4, Canon 85 1.8 and a Canon 70-200L IS II.
On my T1i, there is no micro adjustment. The Sigma is really far off to the point that it is unusable. The Canon 85 is dead on accurate, even at 1.8 and the 70-200 is ok, but seems just a bit off.
Now, on my 5DII, the Sigma needs +20 micro adjustment, the Canon 85 needs +12 micro adjustment and the 70-200 is dead on at 0.
So I guess the moral of the story is, dont judge lens performance of another's lens based on its performance on their camera bodies. :D
Shane
JeffreyG
Gallery: 42 photos
Mar 14, 2012 20:59 |  #2
This could be interesting. I have had some really strange MA experiences myself.
A few of my lenses, the 50L and 85L especially have needed a lot of MA to work on my 1D4. I'll use the 85L as an example.
Focusing from 15 feet away, the 85L will actually backfocus by roughy two feet when the MA is set to zero on the 1D4. An MA of -17 solves the issue.
But here is the part I really do not understand. The 85L (MA = -17) and the 50L (MA = -15) both focus perfectly on my 5D classic which is not even capable of MA.
What does that mean?
Oh, BTW I do have other lenses that focus on the 1D4 with either zero or a bit of positive MA, so the disconnect is not just that my 1D4 body needs tons of negative MA with every lens. It does not.
IMO the lesson is....well, I don't know what the lesson is other than do not be afraid if you need a lot of MA to make a lens work. It might be fine on other bodies.
District_History_Fan
Mar 14, 2012 21:45 |  #3
JeffreyG wrote in post #14088265 (external link)
It means that complex systems function is a sum of the component tolerances.
www.ericmcferrin.smugm​ug.com (external link)
ejenner
Gallery: 98 photos
Joined Nov 2011
Mar 14, 2012 22:29 |  #4
This is the weirdness that flies in the face of what we would think is going on. (I assume that the lenses that have 0 MA on the 1DIV are also OK on the 5D?)
My opinion: Its partly the manufacturing tolerances, but also has to do with exactly how the AF and each lens communicate, so that each combination of lens and body can be potentially different.
I wonder if you's get the same weirdness with two 1DIV's and a set of lenses? Most of what i have seen reported is between different lenses and different bodies not behaving in any consistent manner.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
iLvision
Joined Oct 2011
Mar 14, 2012 22:38 |  #5
Man... Y'all scaring me. Now I'll have to go home after work and test my 85L II that I got a week ago. I only used it on one 5DII.
Now that you brought this up, I'll have to test it out on my SECOND 5DII.
Ilya | Gear | flickr (external link) D800| 14-300mm f/1.4GL ED VR III USWM
Cesium
Mar 14, 2012 22:52 |  #6
District_History_Fan wrote in post #14088483 (external link)
This pretty much sums it up. I've definitely had lenses that worked fine on one body and were off on others. Also a good reason to not buy any new bodies without the MA function.
JeffreyG
Gallery: 42 photos
Mar 15, 2012 05:21 |  #7
Cesium wrote in post #14088814 (external link)
On the other hand, I ran over a dozen lenses on a 30D and 5D before MA was invented and only one of them had a focus problem (135L). And even that lens was probably not correctable by MA because it focused fine at near distances and then progressively backfocused at longer ranges.
I guess that's the part I struggle with. The bodies I have owned that allow for MA also really need MA. The bodies I owned that didn't have MA also didn't need it.
I know I'm practically alluding to some kind of conspiracy theory here, but it does sometimes feel like the inclusion of MA into bodies gave Canon license to relax tolerances. I hate adjusting lenses to bodies, and now I see on the 1Dx/5d3 that the MA adjustability is going to be even 'better' which means it is also going to be even more work. MA is kind of a mixed blessing. When you have a lens that is off, MA is easier than sending everything in for adjustment. But actually adjusting everything at home is a pain.
soundsk
Mar 15, 2012 06:03 as a reply to  @ JeffreyG's post |  #8
Hi!
Just last night I made a bunch of MA tests on a pair of new primes I bought.
MA'ing is a pain, but for those who might not know of it, FoCal makes the job quite a bit easier (read this thread).
Using the Fully Automatic MA mode of the software and repeating the procedure a few times gave me some pretty consistent results, as long as you do the tests in the right conditions (CFL lighting screws things up, found out the hard way!!:oops:)
MA'ing like this at home takes a bit of time, but it also lets you be more in control and really see how your particular copies behave. I tested several different apertures and one or two distances. You can then by yourself pick a value that best suits your needs.
Like this I found out that my copy of the 50 1.4 isn't particularly sharp, even from f2 to f8, and that @50mm f2.8, my 24-70L is much much sharper.
What I am thankful for is having two bodies - 7D,5DII - with MFA.
http://blissphoto.eu/b​log (external link)
iLvision
Joined Oct 2011
Mar 15, 2012 06:20 |  #9
Dude, just tested my 85L II on both of 5DII's **GASP!!** and it's CRAZY SHARP. No MA needed. I guess 85L II really holds its rep. And I brag about it too much on this forum haha.
hollis_f
Mar 15, 2012 06:34 |  #10
JeffreyG wrote in post #14089718 (external link)
So, you're saying that my 60D is manufactured to higher tolerances than my 7D?
I'm at a total loss to figure out why Canon called this feature Micro adjustement when it obviously has a mega influence on many people's setup.. From my own experiences with the 50D 'micro' adjustment made sense; the difference before and after MA was pretty small. And the same happened with a friend's 1D and my 7D. Any improvements were only really visible if pixels were peeked.
On all three cameras, if MA hadn't been available then I wouldn't have noticed. And I don't notice any problems with my 60D - but of course, that's because it's manufactured to higher tolerances than the 1Dx. ;)
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
modchild
Joined Jul 2011
Mar 15, 2012 07:43 |  #11
I have a 7D and a 5D2 and so far I've only had to MA the 7D for 2 out of 6 lenses and none for the 5D2. At short distances (less than 1 metre) my 50 1.8 needed +10 IIRC and my Sigma 150-500 OS needed +5 to get it spot on. All my other lenses are fine with both bodies, although I will re check the 100-400 when I get a chance to do it properly. Last time I was out shooting with it I missed focus on a few photos at long distance, but that might of been a slow shutter/user combo as the cause.
EOS 5D MkIII, EOS 70D, EOS 650D, EOS M, Canon 24-70 f2.8L MkII, Canon 70-200 f2.8L IS MkII, Canon 100 f2.8L Macro, Canon 17-40 f4L IS, Canon 24-105 f4L IS, Canon 300 f4L IS, Canon 85 f1.8, Canon 50 f1.4, Canon 40 f2.8 STM, Canon 35 f2, Sigma 150-500 OS, Tamron 18-270 PZD, Tamron 28-300 VC, 580EX II Flash, Nissin Di866 MkII Flash, Sigma EM 140 Macro Flash and other bits.
JakAHearts
Mar 15, 2012 08:05 |  #12
hollis_f wrote in post #14089838 (external link)
Hollis, on my 5DII using the 85 1.8 I can see that the focus is off through the viewfinder and Im not even using a manual focus screen.
Shane
Allan.L
Mar 15, 2012 08:15 |  #13
This
hollis_f
Mar 15, 2012 08:56 |  #14
JakAHearts wrote in post #14090097 (external link)
And this is fixable by micro adjustment?
JeffreyG
Gallery: 42 photos
Mar 15, 2012 08:59 |  #15
Hollis, I'll shoot you some saamples later today showing show MA on my 1D4 moves the plane of focus a couple feet. And I'll show how the 5D is spot on with the same lens. There is nothing micro about it.
3,555 views & 0 likes for this thread, 13 members have posted to it and it is followed by 2 members.
1458 guests, 128 members online
