Thread started 16 Mar 2012 (Friday) 23:46
why does my JPEG image appears as different in other image viewers ?
picard
Mar 16, 2012 23:46 |  #1
The color appears a bit darker and look a bit green.
This image looks correct in photoshop.
Canon 1DM4,7D, Rebel XT
580 EX II, 430 EX II
Canon 70-200mm IS II L , Canon 85mm F1.2 L II, Canon macro 100mm F/2.8, 18-55mm kit
Sigma 18-200mm F/3.5-5.6, Sigma 10-22mm, Sigma 50mm F/1.4
Sigma 24-70mm F/2.8 EX DG HSM
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Mar 16, 2012 23:58 |  #2
What other image viewers are you seeing this in? It sounds like they're not color managed, most likely. Either that or you are exporting your JPEGs in a color space other than sRGB.
picard
Mar 17, 2012 00:09 |  #3
I save image in default JPEG. how do I check if image are saved in sRGB? I use image viewer ACD 2.5 pro
S.E.V.
/Include subdirectories, empty directories, and verify.
Mar 17, 2012 00:38 |  #4
In photoshop when you hit ctrl+shift+s or file>save as, you will see on the bottom of the pop up window this: ICC Profile.
IMAGE: http://farm8.staticflickr.com/7049/6989040695_40f76bf9d9_o.jpg
That's how you know you have the right color space you want, it will display it right there. Now you can change it by going to Eidt>Convert to Profile the select the proper destination space and leave everything else and press ok. This will change color spaces, then you can save the image.
Also keep in mind that all viewer have different color spaces, so you will see differences between them all, no way to get them all 100% matching, but if you see major differences then maybe your color space in the image is ProPhoto RGB. You may save as default jpeg but how to you open the image up in photoshop? Do you editd in photoshop from lightroom or do you simple open then thru photoshop directly?
Hope this helped.
Sevan
ShotsInTime (external link) / Gear List /Flickr (external link) / Canon Family Portrait (external link)
- Don't Argue With A Stupid Person, They Will Bring You Down To Their Level And Beat You With Experience.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Mar 17, 2012 10:14 |  #5
All image viewers are not created equal. Even if your monitor is calibrated, your browser can make a difference. For instance, Windoze Explorer isn't color managed, & some browsers aren't either. : WEB BROWSER CHECK - Test Page (external link) - ICC profiles and Photoshop Color Management
So be aware that people viewing your image in other utilities may not be seeing what you think they're seeing. The "good old days" when we only had to worry about them looking at our prints under fluorescent lights are gone forever! ;)
Edit for 2013 info:
Color managed applications: https://photography-on-the.net …hp?p=16010686&p​ostcount=6
Wilt
Mar 17, 2012 10:29 |  #6
The on-screen rendition differences can be quite different with internet browsers!
https://photography-on-the.net …p?p=14040337#po​st14040337
So even if everyone used calibrated monitors, what happens when we each use different browsers can bite use in the arse, too.
3,617 views & 0 likes for this thread, 5 members have posted to it.
1580 guests, 139 members online
