I just picked up a 300 2.8 is an my current tripod is a manfrotto 055xprob with a 498rc2 ball head. Since this isnt one of the really heavy lenses will this be ok or do I have to get a gimbal?
skater911 Goldmember 1,281 posts Likes: 3 Joined Dec 2006 More info | Mar 17, 2012 19:59 | #1 I just picked up a 300 2.8 is an my current tripod is a manfrotto 055xprob with a 498rc2 ball head. Since this isnt one of the really heavy lenses will this be ok or do I have to get a gimbal? Nikon D850 l Nikon 28 1.4E l Nikon 50 1.8 g l Nikon 24-120 F4 l Tamron 100-400 l
Mar 17, 2012 20:05 | #2 i have that tripod and its a beast and the head is rated for 17lbs, so yeah, i think it would suffice. Canon 5d mkii | Canon 17-40/4L | Tamron 24-70/2.8 | Canon 85/1.8 | Canon 135/2L
Mar 17, 2012 20:10 | #3 mike_311 wrote in post #14104698 i have that tripod and its a beast and the head is rated for 17lbs, so yeah, i think it would suffice. That is what I thought, but I always hear people who have a ridiculously beefy tripod. I didn't want to have to buy a new one since this one has been good. Nikon D850 l Nikon 28 1.4E l Nikon 50 1.8 g l Nikon 24-120 F4 l Tamron 100-400 l
Billginthekeys Billy the kid 7,359 posts Likes: 2 Joined Nov 2005 Location: Islamorada, FL More info | Mar 17, 2012 20:30 | #4 I found the Manfrotto 681B monopod is great for the lens when you don't want to set up a tripod or hand hold either. Mr. the Kid.
Mar 17, 2012 20:31 | #5 i wouldn't get a new tripod, i would worry more about whether you should get a collar for the lens so it balances better on the tripod. Canon 5d mkii | Canon 17-40/4L | Tamron 24-70/2.8 | Canon 85/1.8 | Canon 135/2L
minh2pac Senior Member 362 posts Joined Nov 2009 Location: New Orleans, LA More info | Mar 17, 2012 20:33 | #6 your tripod is good enough. you might need a new ballhead though Kevin
stover98074 Senior Member 421 posts Likes: 2 Joined Apr 2010 More info | Mar 17, 2012 21:51 | #7 My two cents, you need to try it, a few exposures should tell you. Perhaps lock the mirror up and try a longer exposure to ensure you are okay. Perhaps take some exposures that you normally would take as well. Canon XSI, Asahi Pentax Auto Bellows, 50 Fujinon EP, 80 El Nikkor, 105 El Nikkor, 135 Fujinon EP
phreeky Goldmember 3,515 posts Likes: 15 Joined Oct 2007 Location: Australia More info | Mar 17, 2012 22:17 | #8 The 055 is easily sufficient. I think the 498 is Manfrottos larger ballhead, and it will technically support the weight.
Mar 17, 2012 22:27 | #9 mike_311 wrote in post #14104800 i wouldn't get a new tripod, i would worry more about whether you should get a collar for the lens so it balances better on the tripod. What do you mean by collar? I came with the factory collar, are you referring to one of he longer plates that go on the tripod foot? Nikon D850 l Nikon 28 1.4E l Nikon 50 1.8 g l Nikon 24-120 F4 l Tamron 100-400 l
Mar 17, 2012 22:29 | #10 stover98074 wrote in post #14105083 My two cents, you need to try it, a few exposures should tell you. Perhaps lock the mirror up and try a longer exposure to ensure you are okay. Perhaps take some exposures that you normally would take as well. I use an old Medium Format Chicago Magestic with geared head (about $100 used) but it is heavy to move unless in the the trunk of a car. I did get it out on a hike on a mountain stream once and got this exposure with a Mamiya 645 N 150 3.5 medium format lens on a Canon XSI. A lighter tripod would have probably worked as well. ![]() I wish I could. I live in San Diego where it rains 5 times a year and the weekend that I get this, we end up having a crazy storm the whole weekend. Typical luck I guess. Nikon D850 l Nikon 28 1.4E l Nikon 50 1.8 g l Nikon 24-120 F4 l Tamron 100-400 l
1Tanker Goldmember 4,470 posts Likes: 8 Joined Jan 2011 Location: Swaying to the Symphony of Destruction More info | Yes, it's a good tripod... but as with any tripod, avoid raising the center-column at all costs. It gets wobbly quick..IMO. Kel
MTStringer Goldmember 4,652 posts Likes: 6 Joined May 2006 Location: Channelview, Tx More info | Mar 17, 2012 22:38 | #12 Billginthekeys wrote in post #14104795 I found the Manfrotto 681B monopod is great for the lens when you don't want to set up a tripod or hand hold either. +1
tripod is fine, try it with that head and see if it works. i had that same setup and would get creep after framing up the shot. drove me crazy.
Mar 17, 2012 22:50 | #14 phreeky wrote in post #14105185 The 055 is easily sufficient. I think the 498 is Manfrottos larger ballhead, and it will technically support the weight. The real problem is how much it will move. You'll probably find that are longer focal lengths the vast majority of ballheads will show noticeable "droop" after you tighten the head which can be a pain (300mm not too bad, but with extenders you'll hate it). I think the most wise investment would either be moving to a gimbal head, or if you don't want to go that far then at the very least change the QR clamp. I have a strong dislike of the RC2 style QR clamps, and you could swap it over to a good arca-swiss style clamp plus a couple of plates (including a nice long one for the 300) for < $150. It will allow you to shift the 300mm lens back and forth quite a bit to pick a much nicer balance on the ballhead. Which ones are you referring to so I can look at them. Thanks Nikon D850 l Nikon 28 1.4E l Nikon 50 1.8 g l Nikon 24-120 F4 l Tamron 100-400 l
phreeky Goldmember 3,515 posts Likes: 15 Joined Oct 2007 Location: Australia More info | Mar 18, 2012 05:10 | #15 skater911 wrote in post #14105324 Which ones are you referring to so I can look at them. Thanks Here are the RRS ones: http://reallyrightstuff.com …px?code=ClampsPro&key=cat
| Latest registered member is Monkeytoes 1351 guests, 180 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
