Thread started 19 Mar 2012 (Monday) 12:03
11x14 prints
Neil ­ B
Mar 19, 2012 12:03 |  #1
how to crop this size in CS5 or Lightroom 4 for prints ?
please help me out, thank you :)
Website  (external link)Twitter (external link) Tumblr (external link) Facebook (external link)500px (external link)
René ­ Damkot
Mar 19, 2012 12:19 |  #2
Set an 11x14 crop Ratio
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Neil ­ B
Mar 19, 2012 12:35 as a reply to  @ René Damkot's post |  #3
i tried that, is there any other way, without me losing the rest of my pic ?
Numenorean
Mar 19, 2012 12:39 |  #4
Neil B wrote in post #14113660 (external link)
No. It's not the ratio your camera takes pictures in most likely. So you have to crop some off. When taking photos, you have to be aware of the intended use, crop ratio, etc. and then compose the shot to allow a crop to work - 11x14 is pretty close to the same ratio as 8x10, though not quite. I always leave space to the sides or top/bottom depending on orientation when doing portrait work so that a standard 8x10 crop will work.
Rimmer
Joined Nov 2010
Mar 19, 2012 13:08 |  #5
This works in Elements so I imagine it will also work with CS5:
Draw the crop box with the desired aspect ratio anywhere on the image.
Next, drag any part of the crop box outside any border or corner of the image.
(This two-step approach is necessary because you can't initially stretch a crop box beyond the image borders, but you can drag it outside once it is created.)
Then enlarge the crop box to encompass all of the image plus some overlap beyond the image borders. Center the image within the crop box as desired.
Select OK. That will add canvas to your image so that it now has a border. The border will be the color of your currently set background color. The resulting image will be the desired aspect ratio and you will not lose any of the original image.
Ace Rimmer -- "What a guy!"
"Smoke me a kipper, I'll be back for breakfast." ;)
Numenorean
Mar 19, 2012 13:09 |  #6
Rimmer wrote in post #14113814 (external link)
And you won't have an 11x14 image either. You'll have a smaller image with a border.
stsva
Gallery: 45 photos
Mar 19, 2012 13:21 |  #7
Are you worried about losing the rest of the image for purposes of printing? In this case there's not a lot you can do about it except by either re-sizing the image to the 11X14 ratio from its original 2X3 ratio (which will distort it), or doing what Rimmer suggested and cropping a larger area than your original image so you have the original image inside a larger 11X14 blank (or whatever color you want to fill with) background.
If you're worried about losing the rest of the image for purposes of saving after you've cropped, just save the cropped image as a new file, such as [original file name]11X14.jpg.
Some Canon stuff and a little bit of Yongnuo.
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
René ­ Damkot
Mar 19, 2012 13:24 |  #8
As long as you don't enter a value in the ppi field (in PS), or don't resize upon export in LR, you won't loose anything except the part you're cropping off.
The fact that you need to crop off a part is because your camera shoots in a 2:3 ratio.
Similar: (from another thread about the same subject)
IMAGE: https://img.skitch.com/20100331-g3exbhk8cw5kp75yifjnd8gjf8.preview.jpg
IMAGE LINK: https://skitch.com/ren​edamkot/nhiti/photosho​p  (external link) Click for large view (external link)
IMAGE: https://img.skitch.com/20100331-fa9thkfrrer7w6etfd4672q9i1.preview.jpg
IMAGE LINK: https://skitch.com/ren​edamkot/nhi1r/photosho​p  (external link) Click for large view (external link)
IMAGE: https://img.skitch.com/20100331-tawggf5949h39egyhnq38jca9f.preview.jpg
IMAGE LINK: https://skitch.com/ren​edamkot/nhi1w/photosho​p  (external link) Click for large view (external link)
nate42nd
Mar 19, 2012 14:41 |  #9
I actually made an attempt at explaining this on video. Maybe it will help, although I think Rene did a good job. I cover the aspect ratio of your camera and what you loose if you print. Fast forward to 2:00 for the juicy stuff.
http://www.youtube.com​/watch?v=sD7ycg_KZAY (external link)
7D - - 17-55 F/2.8 - 24-105 F/4L - 100mm F/2.8 - 50mm F/1.8 - S95 / To see all click here
My Flickr (external link)
Maurice ­ A.
Mar 19, 2012 15:01 |  #10
Save your crop as a copy ,then you will keep the original :) .
M. Aucoin
tonylong
...winded
Gallery: 60 photos
Mar 19, 2012 15:56 |  #11
As has been said, to get a "full bleed" print at 11x14 you have to either crop some of the image off or stretch it to fit.
If you don't want to do that you will need to add borders as has been discussed.
This can be done in Photoshop with a lot of creative options.
In Lightroom, you won't be able to work directly with graphical frames/borders. You could lay out an image onto a particular paper size, centered. If you have to export to a lab, you could try the Lightroom Print to File function.
There is also the Mogrify plug-in for Lightroom with which you can do more work with borders.
Tony
Neil ­ B
Mar 19, 2012 18:58 as a reply to  @ tonylong's post |  #12
thank you everyone, i appreciate all the tips !! :)
2,936 views & 0 likes for this thread, 8 members have posted to it.
11x14 prints
1429 guests, 110 members online
