Thread started 20 Mar 2012 (Tuesday) 18:10
Extension tubes on the 70-200?
pxchoi
Mar 20, 2012 18:10 |  #1
Has anyone tried using extension tubes with the 70-200 f2.8 IS II?
I just cant justify having a dedicated macro lens, but there are some occasional instances when I wished I had one. Are extension tubes the solution?
Patrick Choi
Portfolio (external link) | Flickr (external link) | Facebook (external link)
EOS 7D | 580EX II | 10-22mm f3.5-f4.5 | 17-55mm f/2.8 IS |70-200mm f/2.8L IS II
For Sale: 17-55mm f/2.8 IS | 10-22mm f3.5-f4.5
amfoto1
Mar 20, 2012 20:23 |  #2
Hi Patrick,
This was done with the Mark I and a 25mm extension tube. I would imagine the Mark II would do even better.
IMAGE: http://farm7.staticflickr.com/6201/6143768203_0c2819c423_o.jpg
Black & yellow garden spider in its web
EF 70-200/2.8 IS. EOS-3 camera, Ektachrome 200 film. 550EX flash (fill) and ambient light, tripod. Settings unrecorded. Image digitized with Nikon 4000ED film scanner.
You might do a search in the Lens Sample Photo Archive subforum attached to this one. Maybe someone has posted some lens + extension shots there.
I recommend the Kenko tubeset (external link)... It's a good value and well enough made for use with a heavy lens. Three tubes - 12mm, 20mm and 36mm - are pretty versatile.
Bananapie
Joined Jun 2011
Mar 20, 2012 21:33 |  #3
Look at the 77mm 500D diopter. I was pretty impressed with the quality I have seen in images around the web. I don't have one yet, but it is on the way.
Extension tubes are way cheaper, however..
hubcaps
Joined Sep 2009
Mar 20, 2012 22:19 |  #4
I love the images that I get with my 70-200mm f/4 non-IS. BTW, Art Wolfe used kenko extension tubes with the 70-200mm f4 IS in one of the episodes of Travels to the Edge.
Preeb
Gallery: 150 photos
Joined Sep 2011
Mar 21, 2012 00:09 |  #5
pxchoi wrote in post #14121839 (external link)
I've done some ok closeups with my 70-200 and the 1.4 II TC, but I don't have any tubes. I have been considering buying a set, but haven't pulled the trigger. This was from a few months ago, handheld with 70-200 f4 IS and the teleconverter (zoom was 189 - 265mm with TC). Shot at f4 - 1/250 sec, ISO 200 from about 5 feet away, then cropped. The critter was a bout 1.5" long.
IMAGE: http://i575.photobucket.com/albums/ss196/priebra/PSE%20Tech/Toad.jpg
Rick
6D Mark II - EF 17-40 f4 L -- EF 100mm f2.8 L IS Macro -- EF 70-200 f4 L IS w/1.4 II TC
wcleung
Joined Jul 2011
Mar 21, 2012 02:05 |  #6
I don't have the 70-200. I attached a photo of my rosemary bottle in the kitchen, taken with a Rebel, 50mm f1.8, and all 3 extension tubes from the Kenko set. I cropped slightly to lower the file size. The blurry-ness comes from the bottle and its curvatures.
An even cheaper solution is the reverse lens ring.
Debbie
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/03/3/LQ_586570.jpg
Image hosted by forum (586570) © wcleung [SHARE LINK]
Mark-B
Mar 21, 2012 03:11 |  #7
I use the 70-200 f/4 with extension tubes for close ups of flowers:
IMAGE: http://www.msbphoto.com/img/s3/v38/p656682060-4.jpg
IMAGE: http://www.msbphoto.com/img/s11/v37/p8102902-4.jpg
IMAGE: http://www.msbphoto.com/img/s3/v23/p7387387-4.jpg
IMAGE: http://www.msbphoto.com/img/s3/v23/p62366543-4.jpg
IMAGE: http://www.msbphoto.com/img/s10/v18/p278203854-4.jpg
Mark-B
msbphoto.comexternal link
pxchoi
Mar 21, 2012 13:45 |  #8
Mark-B wrote in post #14124318 (external link)
Very nice work, which extension tubes were you using?
Patrick Choi
BufordFZ1
Joined Oct 2011
Mar 21, 2012 14:01 |  #9
Next question, when you shoot Macro, do you leave the camera in Manual or Macro mode with the 70-200?
A2, 60D, 5DII
Canon EF 17-40mm L
EF 100mm L
Canon EF 70-200mm f/2.8L
Canon EF 400mm f/5.6L USM,Canon 50 1.4, 430 EXII,580 EXII
Staszek
Mar 21, 2012 14:15 |  #10
I shoot the 70-200 with Canon's 12mm extension tube. I haven't needed a longer extension tube for the "macro" type studio work I shoot irregularly.
To answer your second question: Manual mode. Though the 7D and 5D don't offer a macro mode you speak of.
IMAGE: http://farm7.staticflickr.com/6225/6291183566_8b56f21b3b_z.jpg
IMAGE LINK: http://www.flickr.com …s/s_olszewski/6​291183566/  (external link)
SOSKIphoto (external link) | Blog (external link) | Facebook (external link)| Instagram (external link)
Shooting with big noisy cameras and a bag of primes.
Staszek
Mar 21, 2012 14:16 |  #11
Solid work Mark!
Mark-B
Mar 21, 2012 14:17 |  #12
pxchoi wrote in post #14126819 (external link)
I use the Kenko tubes. All but #4 are with just the 36mm tube attached. This is my favorite setup because it gives me nice detail with a decent working distance.
The purple flower in #4 was with all three tubes attached - 12mm, 20mm, 36mm. The flower is only about 1/2 inch across and I was able to fill the frame with it. When using all 3 tubes, I usually have to take the hood off because it will touch the flower and block all the light.
The nice thing about using tubes with the 70-200 is that you can pick your working distance (within reason), focus with the zoom ring, then fine tune your focus with the focus ring (or auto focus). Also, because the lens has internal focus and always stays the same distance from the subject, you can put it on a tripod, and try focus stacking (external link).
Mark-B
cfcRebel
Mar 21, 2012 17:07 |  #13
BufordFZ1 wrote in post #14126885 (external link)
For macro work, I normally shoot in Av or M mode, and turn the lens switch from AF to MF. You want to manually focus when shooting macro.
Fee
Canon | SIGMA | TAMRON | Kenko | Amvona
vulcan2912
Mar 29, 2012 04:10 |  #14
Stunning shots.Absolutly fantastic colour.
cheers
Gary
www.garyforsyth.smugmu​g.com (external link)
Fuji Finepix
22,194 views & 0 likes for this thread, 11 members have posted to it.
472 guests, 157 members online
