Thread started 21 Mar 2012 (Wednesday) 12:20
Strap for 300mm F2.8
seaninsa
Joined Sep 2011
Mar 21, 2012 12:20 |  #1
I recently purchased a 300mm f2.8 and notice that it has two places on the lens to hook up a carrying strap. I currently am using Black Rapid straps to carry my camera with. The question I have, is it safe enough to hook up to the tripod mount on the 300mm or should I find a different type of strap hook directly onto the lens itself?
johnf3f
Mar 21, 2012 16:29 |  #2
I used an old grey Canon camera strap on a 400 F2.8 (6.1 Kilo original EOS model) - worked fine for me. Anything that is secure and reasonably comfortable should do, especially on a relatively light lens. If you are not using the 300 as a "Walkabout" lens then I wouldn't bother with a strap unless you are doing an awful lot of walking as they just get in the way, if you are then get something cheap and comfy.
Life is for living, cameras are to capture it (one day I will learn how!).
hollis_f
Mar 22, 2012 06:00 |  #3
The problem with attaching a strap to the lugs on the lens is that the strap needs to be very long. Here's a pic showing a few straps. From Top to botton - BlackRapid, Canon strap supplied with lens, Optech extra long strap, Canon's standard strap.
IMAGE: http://www.frankhollis.com/temp/straps.jpg
I use the strap supplied with the lens, although I am considering dropping it and using the BR - attached to an Arca-Swiss clamp -
IMAGE: http://www.frankhollis.com/temp/BR%20-%20AS.jpg
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
20DNewbie
"don't listen to me, I'm an idiot"
Mar 22, 2012 07:05 |  #4
I use the stock strap with mine.
Christian.
Feedback: POTN - FM (external link)
sonnyc
Joined Jun 2005
Mar 22, 2012 13:57 |  #5
20DNewbie wrote in post #14131184 (external link)
Same here.
Sonny
Nordwil57
Gallery: 13 photos
Mar 22, 2012 14:36 |  #6
hollis_f wrote in post #14131037 (external link)
Frank,
I believe I saw (in another forum) where you listed the measurements of the Canon stock strap? My 300 2.8 came without one and I'd like to replicate it, perhaps with an Optech and extensions. Can you tell me the original dimension? Also, are the Optech extension connectors trustworthy? I'm scared I may bump one and dislodge the connection.
So you would use the black rapid for carrying, then disconnect to mount on tripod or monopod?
My thought is to get something long enough to keep around my neck while carrying the lens mounted to the tripod/monopod over my shoulder as a belts and suspenders kind of thing.
Thanks for the help, all good info here and it sure beats buying at random when others have already gone thru the vetting process!
Rick
3,478 views & 0 likes for this thread, 6 members have posted to it.
2552 guests, 91 members online
