Has jpegs too, they look fine. I'm sure I'm missing something stupid or it's a setting somewhere. PS doesn't recognize them either.
On a slightly-related note, the CHDK firmware hack really takes this camera to a whole new level.
j-dogg Goldmember 1,292 posts Likes: 8 Joined Apr 2011 More info | Mar 22, 2012 09:30 | #1 Has jpegs too, they look fine. I'm sure I'm missing something stupid or it's a setting somewhere. PS doesn't recognize them either. 5D / 400d / 70-200-4LIS / 50 Mk.I / 28-70
Scatterbrained Cream of the Crop 8,511 posts Gallery: 267 photos Best ofs: 12 Likes: 4607 Joined Jan 2010 Location: Yomitan, Okinawa, Japan More info | Mar 22, 2012 09:36 | #2 Did you check with adobe to see if that camera's raw format is supported? VanillaImaging.com
no, never thought of that. They are CR2's, if that's the case could I use some 3rd-party software? 5D / 400d / 70-200-4LIS / 50 Mk.I / 28-70
Scatterbrained Cream of the Crop 8,511 posts Gallery: 267 photos Best ofs: 12 Likes: 4607 Joined Jan 2010 Location: Yomitan, Okinawa, Japan More info | Mar 22, 2012 09:42 | #4 All Canon raw files are "CR.2", but they are different for every camera. A CR.2 out of a 5D is different then a CR.2 out of a 550D. That's why LR can't read CR.2 files for the new 5DIII yet, even though it can for the mII. VanillaImaging.com
Scatterbrained Cream of the Crop 8,511 posts Gallery: 267 photos Best ofs: 12 Likes: 4607 Joined Jan 2010 Location: Yomitan, Okinawa, Japan More info | Mar 22, 2012 09:47 | #5 A link to the CHDK RAW info page: VanillaImaging.com
Oh well, that will work. Thanks. 5D / 400d / 70-200-4LIS / 50 Mk.I / 28-70
You can set CHDK to write DNG files straight to the memory card.
hnikesch Goldmember More info | Mar 23, 2012 08:25 | #8 +1 on Electric Shepherd I use CHDK DNG option with my SD990 ACR works no problem Hans
Winrar, I got it to work. Took me a minute to figure it out but it's working now. 5D / 400d / 70-200-4LIS / 50 Mk.I / 28-70
traildad Member 230 posts Joined Jan 2008 Location: Northern California More info | Mar 24, 2012 16:35 | #10 If you want to convert photos you already have you should be able to do it with this. Canon A720IS, CHDK
Immaculens creeped by the TF.... More info | Mar 29, 2012 00:07 | #11 Are there a few main/popular CHDK threads on this forum? Electric Shepherd wrote in post #14138166 You can set CHDK to write DNG files straight to the memory card. Select the DNG options in the CHDK Raw menu then you need to also "Create Bad Pixel Bin" from the menu before you can shoot. I've enabled it on my A480 and SX130IS compacts and it works fine, producing DNGs that work with ACR [and hence will be fine with LR].
| Latest registered member is semonsters 1688 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
