Recently, my canon 420ex flash has been firing approximately one second after the master (either 580EXII or MX-14) has fired. Slave and flash are set to channel 1 and group C. what am I doing wrong? Thanks in advance
bifocalod Hatchling 3 posts Joined Dec 2010 Location: Tucson, AZ More info | Mar 22, 2012 18:54 | #1 Recently, my canon 420ex flash has been firing approximately one second after the master (either 580EXII or MX-14) has fired. Slave and flash are set to channel 1 and group C. what am I doing wrong? Thanks in advance
bohuntrshane Member 36 posts Joined Jul 2007 Location: Arizona More info | Mar 22, 2012 20:19 | #2 Hopefully someone will reply, I have the same problem. Shane
Apr 07, 2012 10:28 | #3 My 550ex starts to do that as slave to 580ex sometimes - usually after working fine for 20-40 shots - definitely couldnt be overheating, as i dont shoot that fast...... hopefully we can figure this one out.
alduin Senior Member 915 posts Likes: 1 Joined Jan 2008 Location: Lehigh Valley, PA More info | Apr 07, 2012 10:32 | #4 Something related to second curtain flash, maybe? 7D+BG-E7 | 5D | G9 | 24-70 f/2.8L | 70-200 f/2.8L IS | 100-400L IS | 10-22mm | 50mm f/1.4 | 580EX II | 430EX II | YN565EX
Apr 07, 2012 11:15 | #5 alduin wrote in post #14225267 Something related to second curtain flash, maybe? Nope ! double checked that already.
msowsun "approx 8mm" More info | Apr 07, 2012 11:50 | #6 starlights wrote in post #14225427 Nope ! double checked that already. Everything will work just fine initially with perfect wireless ETTL exposures, and the later the slave will start to behave erratic and fire approx 0 .5 to 1 second later - and the pulse seems kind of weak - but if i set it to manual, it fires normal. (The batteries are normal, and sometimes even when connected to the canon power pack - so couldn't be weak batteries either) Do you mean setting the camera to manual mode? The 420EX has no manual mode. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Apr 07, 2012 12:39 | #7 msowsun wrote in post #14225577 Do you mean setting the camera to manual mode? The 420EX has no manual mode. starlights wrote in post #14225254 My 550ex starts to do that as slave to 580ex sometimes - usually after working fine for 20-40 shots - definitely couldnt be overheating, as i dont shoot that fast...... hopefully we can figure this one out.
msowsun "approx 8mm" More info | Apr 07, 2012 12:58 | #8 The only thing I can think of is that the Canon wireless system incorporates a test function that will fire each slave with a delay just as you describe. Maybe it is the master that is causing the problem? Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
alduin Senior Member 915 posts Likes: 1 Joined Jan 2008 Location: Lehigh Valley, PA More info | Apr 07, 2012 13:46 | #9 Gah, yes! Put it in group B and see if the delay is a little shorter. 7D+BG-E7 | 5D | G9 | 24-70 f/2.8L | 70-200 f/2.8L IS | 100-400L IS | 10-22mm | 50mm f/1.4 | 580EX II | 430EX II | YN565EX
| Latest registered member was a spammer, and banned as such! 2564 guests, 92 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
