Thanks guys for chiming in,but:
That's right,it's not what I want to do.As a matter of fact,before posting here,I saw the flashzebra's product and while it looks professionally made,it just doesn't appeal to me for the simple reason that I want that the connector replace the useless 1/4" under the rubber lid and not another hole in the plastic.
Curtis N wrote in post #14142515
First of all, if you're going to modify your flash, install a 1/8" miniplug, not a PC socket.
Why?
Yep,I see now and then negative opinions about the reilability of the PC-sync connectors (not sure if most of the complaints address to the male or the female type).
But,AFAIK,aside of the better reilability of a 2,5/3,5mm male jacks,I've seen enough flimsy 2,5/3,5mm female receptacles.
Best bet is to buy a modified flash foot.
Not for me,for the reasons above and also because I have advanced skills (I'm a tube amp repairman) so two wires to be soldered are,well...
What I was hoping for is to find a wiring legend of the original Canon's hotshoe,eg.to identify which are the two wires going to the PC sync/3,5mm/whatever 2-pole female connector.
60D,MKIIn,Ds MKIII __EF 50 f/1.4,EF 100 f/2.8 macro,EF 135 f/2.0L,EF 16-35 f/2.8 L II,Tamron 28-75 f/2.8,EF 70-200 f/2.8L,Tamron 70-300 f/4-5.6 VC USD ,EF 2xII TC__Marumi clear glass,UV,ND & CPL__ Kata bags__Speedlite 580EX & Metz 58 AF-2 w/Eneloops__ Sandisk __Vanguard Alta Pro 263AT & TRACKER AP-364 w/SBH-300's
