I'm going to pick up some lenses... two days from now, and I'm still sort of hesitant.
Here's what I want: I have a 24-70 which is great, but bulky and f/2.8. My 50 f/1.8 doesn't cut it as I find that the AF is TERRIBLE. Sometimes I just want to go on a stroll and will hesitate to take the Red-Ringed Brick with me. Sometimes I want to take a picture in low light without flash, and 2.8 is a bit slow (and the 50 is as good as nonfunctional). So I figured I could get primes: the 35 is tiny, and the 85 f/1.8 is recognized for its fast and accurate AF in low-light. Problem solved? Sort of.
The 35 is f/2, and it's not USM, so while I've been told it focuses better than the 50 1.8, I'm not expecting any miracles in low-light. The 85 may be very good, but then again it's also a bit long for indoors. Plus, they're two lenses (duh).
So here I was thinking: hey, could I not wing it with just one? Originally I was set on the 35 mm length as I like the pictures that it allows, but 50 also works OK for street photo. I don't really need the reach of an 85 for the situations I expect to use it in (if I want to take a real portrait, it'll be in decent light and I'll be able to use my 70-200).
The problem is that I simply don't have enough room in my camera bag to accomodate all 3, plus the 24-70, 70-200, flash, batteries, etc. So I need to choose. One would be better, two if really necessary. Which would you pick? Just the 50? 35 and 50? Is there really a point to having two lenses just 15mm apart? Should I stick with the original plan and take the 35 and the 85?
Halp!
