Thread started 23 Mar 2012 (Friday) 15:00
T3i for professional wedding videographer
RTPVid
Mar 23, 2012 15:00 |  #1
My daughter is getting married, and I was interviewing potential videographers. One whose work I like says he uses a Canon T3i as his main video camera. I was surprised at that; I would have thought that the 60D (at least) would have had enough advantages in the UI to make it worth the extra cost for a professional.
Anyone else seen a Rebel being used for wedding videography?
Tom
robertwsimpson
Joined Jun 2010
Mar 23, 2012 15:02 |  #2
for video, the only advantage a 60d has is the swivel screen, but if you've got pro video gear, you probably wouldn't want/need that anyway.
RTPVid
Mar 23, 2012 15:11 |  #3
The T3i also has the swivel screen.
Tom
baita83
Mar 23, 2012 15:30 |  #4
I personally love my T3i for video. I would be more concerned with his portfolio then gear you can have great gear and shoot some horrible shots. Where I live I have seen people with Xsi with kit lenses doing wedding photography lol.
gear:5D mark III,T3i,EF 24-105L, EF 100mm , 300mm f4,50mm 1.8
https://www.facebook.c​om/abwildlife (external link)
robertwsimpson
Joined Jun 2010
Mar 23, 2012 15:48 |  #5
oops I was thinking T2i. That's what I have.
invertz3
Joined Mar 2012
Mar 23, 2012 15:48 |  #6
There are no disadvantages when you compare a t3i to a 60d. There is actually a small advantage such as Video zoom in with the t3i. Other that that, "video wise," the t3i is better in that respect.
If you were to compare them in terms of photography the 60d has a quicker shutter for fast moving objects such as soccer or any sport and that is where the t3i lacks.
Also, if you're questioning if a t3i can live up to professional video then you shouldn't worry. A t3i with a nice set of lenses and an experienced videographer who knows how to edit, can make anything look professional.
Hope this helps.
Current Body-Canon EOS rebel t3i/600d with Meike battery grip
Lenses: Sigma 30mm f/1.4 & Tokina 11-16mm f/2.8
Audio: Zoom H1 with Furryhead windscream, DSLRfilmnoob shock mount, and hot shoe mount
DaleK
Joined Mar 2012
Mar 23, 2012 15:49 |  #7
The only difference for video is the slight ergonomic improvements of the 60D....
I shoot with a 550D (T2I), 60D, and a GH2. The Canons have the same sensor, I would check if he had some fast glass and knew how to use his kit - look at the demos.
For reference this was shot on a T2i http://philipbloom.net …sea-canon-rebel-t2i-550d/ (external link)
ben_r_
-POTN's Three legged Support-
Mar 23, 2012 15:52 |  #8
Id be more concerned with how MANY cameras hell be using if hes using DSLRs and what hes doing for audio. The Rebels and the X0D cameras only record 12 minutes at 1080P before the file has to break, which means a gap in the ceremony coverage. So you have to use two (or a 5D3) in order to get seamless coverage (if thats what youre hiring him for). That AND, whats he using to get good audio. If its on board, forget it, thatll sound terrible.
RTPVid
Mar 23, 2012 16:15 |  #9
Addressing some of the items raised here.
I liked his work. That was the first priority, not his equipment.
For continuous coverage, he uses a stationary camcorder that uses digital tape, a Sony camera of some type. I'm not familiar enough with Sony to say what exactly it was, but perhaps miniDV. He uses the T3i for mobile shooting. He carries two and/or uses a second shooter (depending on what you are willing to pay for).
He uses a separate audio recorder with a lavalier mike attached to either the groom or the officiant, plus he asks for a audio CD recording from the sound board, if available, for backup.
So, he's thoroughly professional has has been around since the tape days. I was just surprised at his choice of the T3i.
Tom
joeblack2022
Joined Sep 2011
Mar 23, 2012 16:17 |  #10
RTPVid wrote in post #14140591 (external link)
What advantages specifically? Maybe he is running Magic Lantern?
Just food for thought, I'm not drawing any conclusions myself here.
Joel
ben_r_
Mar 23, 2012 16:22 |  #11
RTPVid wrote in post #14141140 (external link)
Ah, well if youve seen his work and are happy with it thats all that matters. As far as Canon DSLR video goes there is no advantages at all going from the t2i, t3i, 60D, or 7D. They all use the exact same sensor and shoot video exactly the same. You dont hit anything different or better until the 5D2 and now 5D3, 1DIV and 1DX.
Numenorean
Mar 23, 2012 16:34 |  #12
If you like his work, that is what matters.
As far as the Rebel...well the video quality difference you probably won't be able to tell the difference between that, 60D, 7D, etc. in good light. So why spend more money if you'll never use the still photo part? Especially when it sounds like he has everything else needed - audio recording, stationary cameras, etc.
Busted ­ Knuckles
Joined Nov 2011
Mar 24, 2012 08:04 as a reply to  @ ben_r_'s post |  #13
1st if they aren't using Magic Lantern on the camera for video I would seriously question how serious they are about video.
With Magic Lantern the files are fairly close to seamless and 12 minutes can be exceed, I agree on sound, needs to have a separate sound capture system. Certainly having a couple of recorders strategically placed, couple of boom microphones mounted on stands tucked visually out of the way, etc.
The T3i is so inexpensive they should have several at different angles so that when the file size limits hit, and they will be an edit to a different shot can be spliced in so it is seamless - sound track is again recorded separately
If you see me with a wrench - call 911. 5d3, T3i, 17-55 2.8, 50 1.8, 70-200 2.8 L II, 24-105 f4. YN 565, Precision Lupe attached to hacked extended eyecup (no sticky frame) - old enough to have owned an original F-1
cfvisuals
Joined Mar 2011
Mar 24, 2012 08:56 |  #14
5D > all .
5∞ portfolio (external link)
kiapolo
Gallery: 23 photos
Joined Nov 2010
Mar 24, 2012 10:26 |  #15
Only real benefit I see of the 60d is the ability to set custom white balance values, so he could match white balance accross multiple cameras.
| kiapolo.com (external link) (blog) | Gear List | Flickr (external link) | YouTube (external link) | 2012 Project 366 (external link) |
10,480 views & 0 likes for this thread, 13 members have posted to it.
1380 guests, 135 members online
