Thread started 23 Mar 2012 (Friday) 17:10
Compressing mov files
ampeed
Joined Mar 2012
Mar 23, 2012 17:10 |  #1
I normally compress files using a certain program, however it doesn't compress .mov files :rolleyes:. What're some programs used to compress .mov files? Thanks in advance.
Mar 24, 2012 01:27 |  #2
I use final cut using "export using quick time conversion"480x270 hope this helps.
invertz3
Joined Mar 2012
Mar 24, 2012 02:34 |  #3
I use AVS video converter.
Current Body-Canon EOS rebel t3i/600d with Meike battery grip
Lenses: Sigma 30mm f/1.4 & Tokina 11-16mm f/2.8
Audio: Zoom H1 with Furryhead windscream, DSLRfilmnoob shock mount, and hot shoe mount
Anke
Mar 24, 2012 02:41 |  #4
Do you mean compress them to make the file size smaller for emailing? Like zip files?
Also it helps to let us know what OS you are using.
Anke
Tony-S
Mar 24, 2012 12:17 |  #5
Handbrake.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
Mr. ­ Freedom ­ .45
Joined Mar 2012
Mar 24, 2012 13:57 as a reply to  @ Tony-S's post |  #6
Handbrake is good, but the correct way to do it is transfer the videos from your camera to the hard drive and then open them in the video editing software and do whatever you want to do to that video to make it better and then let the editing software do the compressing.
ampeed
Joined Mar 2012
Mar 24, 2012 18:13 |  #7
Mr. Freedom .45 wrote in post #14145693 (external link)
Actually, I was thinking about this. Editing the clips/movies (what ever term you like) in Sony Vegas and then saving the file. I can't remember but it does convert it in to a different file in which I can compress entirely, correct?
Mr. ­ Freedom ­ .45
Joined Mar 2012
Mar 25, 2012 02:29 |  #8
ampeed wrote in post #14146808 (external link)
Yes and the editing softwares have lots of different setting to choose when saving the file.
ampeed
Joined Mar 2012
Mar 25, 2012 14:28 |  #9
Mr. Freedom .45 wrote in post #14148594 (external link)
Thought so. Its been about 2 years :o
BoysClub
Joined Mar 2012
Mar 25, 2012 17:34 |  #10
The best/fastest method I've used is Quicktime Pro 7. It's actually faster than Compressor and FCP.
Export your FCP timeline as a Quicktime move (not quicktime compression). This should take under a minute since there is no compression going on. Then open that file in QT Pro and export it 1280x720 for web with the bitrate anywhere between 5000 - 9,000 depending on how big you want it to be.
Tony-S
Mar 25, 2012 19:24 |  #11
I don't understand that at all. Handbrake is free and will do that plus it has many presets.
BoysClub
Joined Mar 2012
Mar 27, 2012 10:57 |  #12
Tony-S wrote in post #14152276 (external link)
Preference, I guess. I don't like handbrake because it's slow and I don't see any use for presets because they're often not the best quality you could be getting. QT Pro has given me the best image quality of the bunch, and it's fastest.
Tony-S
Mar 27, 2012 12:06 |  #13
BoysClub wrote in post #14162423 (external link)
This is not my experience. On my 12-core Mac Pro, Handbrake uses all 12 cores and hyperthreading, while QT Pro only uses 4 cores and no hyperthreading.
joeblack2022
Joined Sep 2011
Mar 27, 2012 16:55 |  #14
ampeed wrote in post #14141506 (external link)
What do you intend to do with the files? Post on YouTube, etc.?
Joel
ampeed
Joined Mar 2012
Mar 27, 2012 22:01 |  #15
joeblack2022 wrote in post #14164396 (external link)
vimeo and youtube. Why do you ask?
10,973 views & 0 likes for this thread, 10 members have posted to it and it is followed by 2 members.
Latest registered member is vinceisvisual
888 guests, 179 members online
