Thread started 23 Mar 2012 (Friday) 22:57
1D3/1D4 Wide angle lens
kenjancef
Gallery: 20 photos
Mar 23, 2012 22:57 |  #1
As the title says, I am looking for a wide angle, or ultra wide angle lens to use with my 1D3/1D4. I'm not sure what is compatible, but I did have a Canon 10-22 that I used on my old 7D, and it was the sharpest lens I've ever had, and I know I can't use that on the bodies I have. Hopefully not expensive, since it won't really be a full time lens, but nice to have, if that makes sense... Plus, I have a 24-70, so I'd like it to be shorter than that. Not sure if there is a 10-22 equivalent for what I can use.
Thanks for all help.
Higgs ­ Boson
Mar 23, 2012 22:59 |  #2
16-35 is the 10-22 equivalent. aps-h can't use efs, only ef....but it's still a crop so you lose width.
A9 | 25 | 55 | 85 | 90 | 135
kenjancef
Gallery: 20 photos
Mar 23, 2012 23:09 as a reply to  @ Higgs Boson's post |  #3
Yea, I knew I couldn't use EF-S lenses... :)
Thanks for the suggestion, will check that one out.
Gomboman
Mar 23, 2012 23:22 as a reply to  @ kenjancef's post |  #4
The Tokina 11-16 might be your best bet.
1D Mark III | 1D Mark IIN | 5D | 17-40L | 24-70L | 70-200L II | 1.4 TC II| 550EX | And some other stuff
My flickr (external link)
DreDaze
Gallery: 49 photos
Mar 24, 2012 03:23 |  #5
you could just do this if you want to use the 10-22mm:
http://www.benjacobsen​photo.com …-ef-s-to-ef-conversion-2/ (external link)
if you're worried about the mount hitting the camera then you can get a third party lens...the sigma 10-20mm is a cheaper alternative if you don't want to spend the $$
Andre or Dre
gear list
Instagram (external link)
kenjancef
Gallery: 20 photos
Mar 24, 2012 08:49 |  #6
DreDaze wrote in post #14143779 (external link)
Don't want to do any mods, and yea, I'm worried about things getting hit..
And I don't want to spend too much since it won't be an "every day" lens.
Thanks for the recommendations!
jvk
Mar 24, 2012 09:12 |  #7
Samyang 14mm? Only MF though.
Camera: Canon EOS 7D / Nikon Coolpix A / Hasselblad xpan
Lenses: Canon EF 16-35mm f/2.8L USM / Canon EF 24-105mm f/4L IS USM / Canon EF 80-200 f/2.8L / Canon EF 300mm f/2.8L USM
kenjancef
Gallery: 20 photos
Mar 24, 2012 09:17 |  #8
jvk wrote in post #14144539 (external link)
Heard a lot of good about that lens, not sure about MF, but thinking about it.
h4ppydaze
Joined Oct 2011
Mar 24, 2012 14:05 |  #9
manual focus at that focal length is extremely forgiving... Even 2.8 has a very wide depth of field. Might want to give the Sigma 14mm 2.8 a go
kenjancef
Gallery: 20 photos
Mar 24, 2012 14:17 |  #10
h4ppydaze wrote in post #14145741 (external link)
My eyesight isn't what it used to be, but tempted to try. I will look into the Sigma too. Awesome suggestions, thanks!
kenjancef
Gallery: 20 photos
Mar 26, 2012 21:33 |  #11
Gomboman wrote in post #14143176 (external link)
Just looked up this lens on B&H. Says it will NOT work with a camera with a sensor bigger than APS-C. So seems it won't work with a 1D3/4. Or does it? Confused...
DreDaze
Gallery: 49 photos
Mar 26, 2012 21:38 |  #12
kenjancef wrote in post #14159573 (external link)
it'll vignette at the wider focal lengths...but it'll work towards the longer end...
https://photography-on-the.net …21300&highlight​=1D+tokina
https://photography-on-the.net …php?p=7655688&p​ostcount=9
Andre or Dre
gear list
kenjancef
Gallery: 20 photos
Mar 26, 2012 21:41 |  #13
DreDaze wrote in post #14159624 (external link)
Oh, ok. I thought that even mounting it would cause mirror issues and such, kinda like putting an EF-S lens on a full-frame.
Thanks for the info!
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 26, 2012 22:00 |  #14
kenjancef wrote in post #14159646 (external link)
The lens will vignette for 1.5mm on the wide end, but you can use the rest of the range, it works great.
noisejammer
Mar 27, 2012 16:53 |  #15
I've used the OM 16 fisheye and TS-E 17/4L on my 1D4. Both work very well. The TS-E is particularly useful because you can make instant panoramas with the lens moving either left-right or up--down relative to the sensor axis.
There's also the Zeiss ZE 15/2.8 but at ~$3k, that's riding in the Leica price bracket. If memory serves, it will be available in May.
Manual focus is a breeze, particularly if you install one of the split prism screens. Even better, install a Zacuto ZRF frame and use a Zacuto Z-finder loupe with live view.
Several cameras and more glass than I will admit to.
3,991 views & 0 likes for this thread, 11 members have posted to it.
1596 guests, 139 members online
