FORUMS Photography Talk by Genre Critique Corner
Thread started 23 Mar 2012 (Friday) 23:45
Architectural - Patio shot - need harsh critique
stayhumble
Joined Nov 2010
Mar 23, 2012 23:45 |  #1
I am a contract photographer for a patio company and strive to produce the best work with the amounted time i have.
I appreciate any and all PROFESSIONAL comments and suggestions. I'm only here to learn.
I would prefer advice from working professionals who know whats expected as an interior/architectural photographer, but wouldnt mind other advice.
And yes, I should have shot a later time, but this is the time I HAD to shoot at.
Thanks in advance
IMAGE: http://pcdn.500px.net/6022307/aff2bfd7241a4f4417cf70126df7106ed27445b4/4.jpg
There are no rules for a good photograph and there are no excuses for a bad one.
SELLING:40D, 50D, 10-22, Tamron 17-50 non VC, 5D, 14MM II, 24-105, 70-200 f/4 IS, 430EX, 530EX (ALL MINT W/Box)
tmoore323
Mar 24, 2012 00:52 |  #2
I'm thinking something more like this:
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i1259.photobuck​et.com/albums/ii547/tm​oore323/4.png (external link)
Titus213
Mar 24, 2012 01:02 |  #3
I would think...a different angle would be better here.
Since there is nothing of dramatic interest on the right of the image what would it look like if you took a couple steps to the right and shot the back of the house and the deck? Wide angle, cover the back of the house, the deck, and the upper room. I would also shoot landscape orientation.
tmoores edit helps a bunch.
Dave
Perspiring photographer.
argyle
Mar 24, 2012 05:56 as a reply to  @ Titus213's post |  #4
Not a fan of the distortion from using a 17mm lens. If you're going to shoot architectural, you should keep the verticals vertical and the horizontals horizontal. Also, using a lens that wide gives a "false" dimension to the viewer...makes the room or whatever space you're shooting appear to be much larger than it is. Patio looks a bit cluttered in the background (what's that yellow thing behind the grill?).
The original is lacking contrast and doesn't have any 'pop'. Use of a polarizer would have helped to kill the glare on the glass tabletop (or enhance the reflection). A better angle would have helped, but I can see how the fence might have prevented that from happening. The edited version blackened the shadows too much and took away some detail.
Qbx
Gallery: 49 photos
Mar 24, 2012 11:22 |  #5
If the idea is to show the patio then a wide lens making it look bigger than it is - is probably a good idea. Plus you got some of the overhead room in the frame as a bonus. I think Tmoore's edit is about right because the shadow detail that is lost is not important to the main point of the image. Given the geography there I doubt another angle would be workable.
-- Image Editing OK --
argyle
Mar 24, 2012 14:49 as a reply to  @ Qbx's post |  #6
If the goal is to just show the patio (I'm assuming you mean the tiling/stonework), then it would be best to remove everything (furniture, grill, clutter) before shooting so as to make the stonework the center of attention. If the goal is to show the patio as an outdoor living space, then everything should complement one another, with detail. The chosen focal length and angle really stretches the patio length, to the point where the table at the far end seems waaaaay far away. IMO, the over-saturated reds in the edit are now the first thing that one's eyes lock onto, making the tiled floor an afterthought.
kooker
Joined Mar 2012
Mar 25, 2012 18:40 |  #7
argyle wrote in post #14145912 (external link)
How about moving the furniture closer to the grill, so that stonework is clearly visible in the foreground and the furniture in the background suggests wonderful outdoor living space. Not a professional thought.
mltn
Gallery: 6 photos
Mar 25, 2012 22:52 |  #8
argyle wrote in post #14144034 (external link)
I agree with all of this except for the angle. This angle has been used many times, and it often looks good, as long as the verticals are perfectly vertical, which they are slightly off in some parts.
If he was perfectly straight on here, then part of the frame would include the side of the house, which I think would be distracting. Part of the appeal of this photo is the view that goes along with the patio.
Was the original an HDR? It's got some serious weird things happening in the shadows.
I don't mind the distortion, only that there's a discernable object in the part of the frame that's distorted, if that makes sense. So at the bottom, there shouldn't be a chair going out of the frame, because the distortion makes it distracting. That whole furniture set is kind of distorted, and I wish there was a lot more space between the bottom of the frame and the furniture.
Did you shoot this on a tripod? Ideally you would set up the shot, and then be able to move things around so you could easily mask them in or out of the photo. So you could have an empty patio, or you could only have certain furniture items. This would take a while, but it's tough to judge how to style a space like this.
Also if you have any strobes or speedlites, you could light different parts of the image and have a better control on the exposure. This is also time consuming, but the results will be much better than HDR, check out this article where Frank Meyl discusses this technique:
http://www.thefstopmag​.com/?p=1093 (external link)
1,210 views & 0 likes for this thread
Latest registered member is bushpilot
663 guests, 314 members online
