Thread started 24 Mar 2012 (Saturday) 00:52
a head or L plate?
EOS ­ mE
Mar 24, 2012 00:52 |  #1
which to get? i've been having some creep issue when i put the my gear on my dolica when it's on the side taking portrait orientation. the head creeps like crazy.
i thought about getting a Giottos MH1300-657, but after seeing the RSS video about the L plate (external link), i was thinking maybe getting a L plate would do the trick instead of getting a new head.
my friend suggested me to get this L plate (external link), which is very similar to the RSS L plate.
my only beef with this is that i'm not sure if it will fit my 5D2 with grip.
what would you suggest? head or L plate?
5DMKII Gripped | 30D Gripped | 50mm f1.4 | 24-70mm f2.8L | 70-200mm f2.8L IS | 430EX | 580EXIIhttps://photography-on-the.net/forum/showthre​ad.php?t=416554
My Reviews:
KATA 3N1 - 25PL Bag, Dolica CF Tripod ZX600B103
mzondeki
Mar 24, 2012 00:58 |  #2
L Plate makes life so much easier, even you can mount on not-so-strong heads.
I mount 5Dc + Lplate + Tamron 70-300 Vc comfortably on Horusbennu LX3 head. No problem.
My vote for L plate.
RX100V, A7 + Contax Zeiss [28/2.8, 50/1.4, 100/2, 135/2.8]
https://www.flickr.com​/photos/53182994@N06/ (external link)
EOS ­ mE
Mar 24, 2012 01:25 |  #3
that's what i was thinking as well.. going this route, i wouldn't have to change heads. :)
My Reviews:
rick_reno
Mar 24, 2012 09:55 |  #4
I've got L's on my bodies, they work well. Mine are RRS.
Wilt
Mar 24, 2012 11:04 |  #5
An L plate will help to alleviate head droop when camera is in Portrait position (rather than using the drop slot), but only a new head (or tripod mounting bracket on the lens) will alleviate head droop when a long lens is mounted on the camera! And if you want long lens on camera in Portrait orientation, you need both.
NU27D
Mar 24, 2012 14:40 as a reply to  @ Wilt's post |  #6
RRS or Kirk L plate! I have RRS. The one linked appears not to have "accessory door access".
klr.b
Mar 24, 2012 17:32 |  #7
I'd recommend a better head. Like Wilt says, the L bracket will help in portrait orientation, but only when the ball stem is perfectly vertical. If the head creeps, it will still creep with an L bracket. If you only shoot straight on, then it might not make a difference to you.
gordon
Gear and Feedback
EOS ­ mE
Mar 24, 2012 18:23 |  #8
yea, the link for the sunway version doesn't have the accessory door access, which is sucks. but right now they are in the process of making the one for 5D2 with battery grip. so hopefully they'll keep that in mind when they design.
i thought about just getting a new head to just be happy with it.. so i had my mind set on the Giottos MH1300-657. my boss has the RSS for his D3 and looks very rock solid!
guess i'll just have to save up for both the L plate and the head. :)
My Reviews:
1,347 views & 0 likes for this thread, 6 members have posted to it.
a head or L plate?
1381 guests, 120 members online
