Thread started 24 Mar 2012 (Saturday) 17:26
How do I use a CPL (polarizer)?
Polarized
Joined Mar 2012
Mar 24, 2012 17:26 |  #1
Contrary to my name I really have no clue how to use this thing.
I get the whole 90 degree to the sun using my hand as a gun kinda thing... but what I don't get is why the filter turns? Why would I rotate it?
klr.b
Mar 24, 2012 17:35 |  #2
CPLs are adjustable. Sometimes you don't want/need maximum polarization.
gordon
Gear and Feedback
Polarized
Joined Mar 2012
Mar 24, 2012 18:14 |  #3
How do you know when it's at max polarization?
klr.b
Mar 24, 2012 18:47 |  #4
It depends what you're doing. Look through the viewfinder or Live View and watch the reflections (if that's what you're trying to prevent). Since my CPL wasn't marked, I mounted it, and held it in front of my computer's LCD monitor and took note of what happened as I rotated it. At full polarization, it looks black. You can use a white-out pen or something to mark that point on both outside rims of the CPL.
gordon
Gear and Feedback
crn3371
Mar 24, 2012 19:46 |  #5
I just rotate it until I get the desired effect.
Jon
Joined Jun 2004
Mar 25, 2012 20:29 |  #6
When you think it might help, put it on the camera and rotate it as you look through the viewfinder. You'll either see a change as it turns or be in a situation where it won't help. If you see changes when you turn it, keep going until you like what you see, be it deep blue skies or reduction/enhancement of reflections from non-metallic objects.
Jon
Cocker Spaniels
canonphotog
Joined Nov 2005
Mar 25, 2012 20:33 |  #7
crn3371 wrote in post #14147182 (external link)
+ a gazillion!
-Ken
Gear List|Kenny D. Photography (external link)
canonphotog
Joined Nov 2005
Mar 25, 2012 20:37 |  #8
On a more serious note.., Don't worry about 90 degrees to the sun, throwing salt over your shoulder or finding a pair of ruby slippers.
Point your lens, with polarizer mounted, at something with glare. Metal or windshields are very good for this. While looking through the viewfinder, turn the filter until the glare or reflection is minimized. You've now adjusted the polarizer for optimum effect.
Set your exposure and start shooting.
Enjoy your polarizer!
-Ken
argyle
Mar 26, 2012 06:23 as a reply to  @ canonphotog's post |  #9
Polarized wrote in post #14146562 (external link)
Polarized wrote in post #14146813 (external link)
You need to be careful when using a polarizer. First off, its not the type of filter that you want to keep on your lens 100% of the time. Second, you may not always want "max polarization" dialed in...there's nothing worse than looking at an image with a sky that has been over-polarized (the navy blue color is usually the giveaway). You should be judicious in how much polarization you dial in...think of it as "season to taste" in cooking terms. Rotate until you have the desired effect.
Also, when looking through the viewfinder, be sure to rotate the polarizer in a counter-clockwise direction...this will ensure that it won't accidentally screw off from the lens and fall to the ground (or in the water).
sandpiper
Mar 29, 2012 07:41 as a reply to  @ argyle's post |  #10
In addition to adjusting the strength of the effect, rotating the filter can adjust where the effect occurs too. If photographing a car, for example, the subject comprises many angles so, at one point of filter rotation, you may kill reflections on the bonnet and windscreen but leave the reflections on the side of the car. Rotating the filter can then move the area affected to kill the reflections in the side windows and bodywork but bring back the reflections in the windscreen etc.
The simplest way to understand what it is capable of doing, is to stick one on your lens and look through it while you play.
dsblk93gt
Joined Apr 2011
Apr 10, 2012 17:47 |  #11
When I was using a CPL recently what I saw through my viewfinder looked great but the actual picture was not, it did not make much sense to me.
Canon T1i - Canon 50mm f/1.4 USM - Tamron 17-50 f/2.8 non-VC - Tamron AF 70-300mm f/4.0-5.6 SP Di VC USD XLD - 430 EX II
sandpiper
Apr 10, 2012 17:53 |  #12
dsblk93gt wrote in post #14243776 (external link)
In what way was it different? Don't forget that you look through the viewfinder in real life, an image is affected by exposure and other settings.
2,524 views & 0 likes for this thread, 8 members have posted to it.
2261 guests, 125 members online
