I shoot real estate and use the 5d MK II with the TS-E 17mm and shoot in AV, ISO 100, 6 exposures from -4 to +4. My F stop is 22. Could I shoot at a lower F stop and still get clear pictures? I use photomatix to blend my pictures.
mike3767 Member 242 posts Joined Dec 2010 More info | Mar 24, 2012 20:35 | #1 I shoot real estate and use the 5d MK II with the TS-E 17mm and shoot in AV, ISO 100, 6 exposures from -4 to +4. My F stop is 22. Could I shoot at a lower F stop and still get clear pictures? I use photomatix to blend my pictures. Canon 5D MKII, TS-E 17Lmm, 100Lmm Macro,24-70Lmm, 70-200LIImm
Mar 25, 2012 09:06 | #2 Hello? Canon 5D MKII, TS-E 17Lmm, 100Lmm Macro,24-70Lmm, 70-200LIImm
dedsen Goldmember 2,580 posts Likes: 34 Joined Aug 2006 More info | Mar 25, 2012 09:15 | #3 A wide lens like a 17mm generally has good DOF without stopping down that far.
airfrogusmc I'm a chimper. There I said it... More info | Yes. I would recommend using a DoF as close to exactly what you need to keep the areas you need sharp, sharp.
| Latest registered member is ealarcon 493 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
