Thread started 25 Mar 2012 (Sunday) 13:49
Focusing issue with 7D
sass25479
Gallery: 14 photos
Joined Mar 2012
Mar 25, 2012 13:49 |  #1
Yesterday while out learning, I was having an issue with the focusing on my new 7D.
I would focus on her face by pressing the shutter button half way and then still holding the button I would recompose the shot. When checking the photo I noticed that her face is not in sharp focus. I was using a Tamron 17-50/2.8 lens. I even tried manual focus with the same result. I also tried both of my Canon lenses and got the same result. Is there a setting on the camera that I've got messed up? Here's an example of what I'm talking about. Thanks for your help.
Steve
1/100 sec at f/2.8 ISO 100
50 mm (17-50mm)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/03/4/LQ_587272.jpg
Image hosted by forum (587272) © sass25479 [SHARE LINK]
ImCBParker
Mar 25, 2012 14:03 |  #2
The 7D's AF is a far more complicated (and better) af system then what you were likely coming from. What AF mode were you shooting with (auto, center, zone, single point)? I suggest doing a quick search for 7D AF. It takes some practice to get use to, but once you do you will love it.
I only shoot single point. It is quick to adjust between shots, but I rarely miss a focus point.
Canon 5DIII, 7D, 40D, 8-14L, 24-70 f2.8L, 70-200 f2.8L IS, 24L, 50L, 85 f1.8, 100L, 135L, 1.4 Extender, Tokina 16-28 f2.8, and too many lights and accessories to list.
Website (external link)
sass25479
Gallery: 14 photos
Joined Mar 2012
Mar 25, 2012 14:12 |  #3
Yes, my last camera is a 10D so there's a big learning curve. I think that I was on spot. Let me check.
sass25479
Gallery: 14 photos
Joined Mar 2012
Mar 25, 2012 14:14 |  #4
spot looks like this (o) right?
Hitthespot
Joined Mar 2011
Mar 25, 2012 14:16 as a reply to  @ ImCBParker's post |  #5
If you press the shutter button half way the camera will focus on which ever focusing point (s) you have selected. If you hold the shutter button half way it will only hold that focus only if your camera is set to one shot. If the camera is set to Al Servo mode the camera can continue to focus on the selected focus points as you move the camera around. From what I can see in the photograph you posted the focus point is well in front of her face. This most likely tells me that the focus point used was probably somewhere else other than her face when you fired the shot. Especially if the camera works fine when you don't recompose the shot.
The only thing that throws me a little is you said you had the same result using manual focus. If you manual focus on her face then you should always be in focus there unless you manually change it. Not sure about this? IS it possible you haven't adjusted the focus of your vue finder piece for your eyes?
I hope this helps.
Bill
Canon 7D, 24-105 f/4L IS, 70-200 f/4L IS, 100-400 f/4.5-5.6L IS, 430EX II,
nate42nd
Mar 25, 2012 14:20 |  #6
There IS a possibility that the body and Tamron lens need to be adjusted in MA. (in you camera's menu) but that's a tricky operation.
I would make sure you are in single point focus.....set your camera up so you can moe the focus point around with the 8 way joystick. This way you don't need to focus on the face and recompose. You can simply move the focus point to her face and compose how you want.
If that does not work you mgiht have other issues. Look into AF microadjustment C fn III -5 in your menu. READ about it before you do anything. It's not for everyone.....especiall​y if you are just learning. Just know it's available.
7D - - 17-55 F/2.8 - 24-105 F/4L - 100mm F/2.8 - 50mm F/1.8 - S95 / To see all click here
My Flickr (external link)
sass25479
Gallery: 14 photos
Joined Mar 2012
Mar 25, 2012 14:22 |  #7
I checked the camera, it's set to AI. Thanks, I'll give it another try.
Hitthespot
Joined Mar 2011
Mar 25, 2012 14:25 as a reply to  @ sass25479's post |  #8
Your welcome. Good luck. Let me know if that helped your problem.
Bill
nate42nd
Mar 25, 2012 14:27 |  #9
sass25479 wrote in post #14150765 (external link)
That's the problem. Set that baby to single point / One shot / view all points all the time in the VF / move the focus points with the joystick /
You will be happy. You might have to look some of that up in your manual.
sass25479
Gallery: 14 photos
Joined Mar 2012
Mar 25, 2012 15:02 |  #10
Ok, I'm back to reading the book. It sucks to get old. Things just don't stay in my head like they use too.
Daship
Mar 25, 2012 15:10 |  #11
Yup sounds like AI was most likely the problem, but since you have a 7D get the focus recompose out of your head. Compose the shot and use one of the many focus spots you have available. Go into custom functions and set the joystick to quick switch focus points.
nate42nd
Mar 25, 2012 15:12 |  #12
sass25479 wrote in post #14150946 (external link)
I was just looking at my setup. I show all focus points all the time in my VF but you can just show the active one and move that around with the multi controller. (or joystick) If you would like to try my set-up.....I will tell you exactly what to change i your menu. Let me know if you need help. You will find the items in C fn III Autofocus / Drive portion of the menu.
Here they are if you want to try:
1. C fn III -7 Continuous
2. C fn III -8 Enable
3. C fn III -9 Depends on whether you want all focus points or just the active one
4. Go to Custom Control screen and make the joystick move the focus point (not the only the finger and thumb dials)
That will make things easier.
bobb ­ d
Joined May 2011
Mar 25, 2012 16:05 as a reply to  @ nate42nd's post |  #13
It looks like you may need to micro adjust the lens as your subjects shin area looks in focus or it could be the autofocus set up. have a nosey at this video/
http://www.youtube.com …gTGlGYz4WvJK13r​kHhvpBU%3D (external link)
HTH, Bob
7D, 70-200 f2.8 L non IS USM, 18-135mm EFS, 10-22mm f/3.5-4.5, 70-200mm f/4 L IS USM, 100-400mm f/4.5-5.6 L IS USM, 50mm Mk2 1.8, 85mm 1.8, 17-55mm 2.8, 580 EXII, Manfrotto 055XB & 804RC2 head..........no money left now:p
cfcRebel
Mar 25, 2012 17:00 |  #14
Also, becareful with the 7D's center focus point with 4 addtional nearby Assist AF points because one of the Assist points might pick up her knee and thought that's the area it should focus on. It happened to some of my shots. However, the center focus point + 4 nearby assist is very useful with shot where the subject clearly stands out from the bg, such as a bird inflight.
Fee
Canon | SIGMA | TAMRON | Kenko | Amvona
2,787 views & 0 likes for this thread, 7 members have posted to it.
1053 guests, 104 members online
