Ah yes, this is what happens when project drift sets in, what started out as a simple comparison of a few fluorescent ends up becoming a full blown manufacturing project.
It all began here https://photography-on-the.net/forum/showthread.php?t=1150222 with my discovery that a few big box stores where selling fluorescent lamps with decent CRI’s of 90+.
I bought a couple of the tubes and a ballast to try them out with planning on converting an old burnt out fixture I had stored somewhere in the shop, however as it turned out that fixture had been tossed in the trash years ago leaving me with two choices, buy a new el-cheepo twelve dollar magnetic fixture and retrofit it, or spend considerably more and build my own.
Well being adventuresome, I decided to try building one of my own and build it out of aluminum nor less, this presented me with a few problems, I have never worked with nor less welded aluminum and while I have a MIG (GMAW) and a stick welder (SMAW), one was not set up for aluminum and the other was not suitable for aluminum, and last but not least I have a couple of suppliers for steel but none for aluminum.
No to be deterred I plodded forward and discovered the MIG could be upgraded, all I needed to do way add a aluminum wire feed and a tank of pure Argon, needless to say I was a happy camper, I then asked how much will this all cost, after hearing the price I decided at dinner that night I would point out at my wife just how nice the kitchen remodel we just completed came out before mentioning my welder up-grade purchase.
Anyhow moving on, what I decided to build was a light enclosure, aka. lamp, one that I could place within four, forty-eight inch T-12 bulbs, the frame of the lamp was fabricated out of one inch by three inch by one-eighth inch thick 6063-T5 rectangular aluminum tubing, I wanted the box to be deep enough to prevent excessive side spill of the light, and to be able to use the barn doors to provide a cover to make a protective cabinet for the tubes while the lamp was in transport.
The rear/reflector of the lamp and the barn doors where sheared out of a sheet of .090 6061-T6 aluminum, the rear of the lamp was given a rough 220 finish and the front was polished bright, the barn doors will be given a 220 finish then primed and painted flat black.
The left and right sides where drilled and a five-sixteenths blind nut was installed, this will allow the lamp to be adjusted within the yoke which will be built out of lighter, one by two inch rectangular aluminum tubing.
| HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
Yea the welding is limp...
Frame being wet sanded.
Make note, less silicone sealant next time....
Wayne
Do what you love and you will love what you do, that applies to both work and life.
