Thread started 25 Mar 2012 (Sunday) 19:14
DOF question/help
Ace ­ and ­ Deuce
Joined Feb 2012
Mar 25, 2012 19:14 |  #1
I have a question about depth of field. How do you get the whole subject 'in focus'? I'm assuming I'm using the wrong lens for the job (as with the ants pic a while back), but how do you 'know' you're going to have a focusing issue? This pic was shot with my 18-55 from a tripod, IS turned off, and a 2 second timer. What am I doing wrong? I can understand the background being blurred, which is cool, but how do you go about getting the whole object in focus?
Chief 2 (external link) by Ace and Deuce (external link), on Flickr
File Name IMG_2589.CR2
Camera Model Canon EOS REBEL T3i
Firmware Firmware Version 1.0.1
Shooting Date/Time 3/25/2012 6:01:32 PM
Owner's Name
Shooting Mode Manual Exposure
Tv( Shutter Speed ) 1/50
Av( Aperture Value ) 5.6
Metering Mode Evaluative Metering
ISO Speed 800
Auto ISO Speed OFF
Lens EF-S18-55mm f/3.5-5.6 IS II
Focal Length 55.0mm
Image Size 5184x3456
Aspect ratio 16:9
Image Quality RAW
Flash Off
FE lock OFF
White Balance Mode Auto
AF Mode One-Shot AF
AF area select mode Manual selection
Picture Style Auto
Auto Lighting Optimizer Standard
Peripheral illumination correction Enable
Dust Delete Data No
File Size 26119KB
Drive Mode Self-Timer Operation
Live View Shooting ON
Thanks,
~Steve
vorlon1
Joined Nov 2011
Mar 25, 2012 19:25 |  #2
Up your AV setting to at least 11, set your ISO accordingly and set the shutter setting to its appropriate value. It's your aperture setting that you want to increase (decrease in size) to get more DOF.
"We don't see things as they are, we see them as we are." -- Anais Nin
5Dc Gripped, 6D Gripped, Nikon D700, Olympus OMD-EM1 Mk2, Fuji XH-1, Pentax 50 1.4, 40mm f/2.8 Pancake, 24-105 mm L, 85mm 1.8, 18-200mm 3.5-5.6, Tamron 24-70mm f/2.8, Olympus 60mm f/2.8 Macro, 70-200mm f/4 L, etc.
Smugmug: http://paladinphotos.s​mugmug.com/ (external link)
crn3371
Mar 25, 2012 19:26 |  #3
Basically, a wider aperture.
oldvultureface
Gallery: 85 photos
Mar 25, 2012 19:30 as a reply to  @ crn3371's post |  #4
This will help:
http://www.dofmaster.c​om/dofjs.html (external link)
Ace ­ and ­ Deuce
Joined Feb 2012
Mar 25, 2012 19:34 |  #5
Thanks. That's kind of what I was thinking, but controlling the light was getting to be an issue for me. I took some at 7.1 and 1/320, but had to raise my ISO to 3200, and they still seemed a bit dark to me. To raise my AV to 11, I would need my shutter around 1/50, correct (while running ISO 3200)?
FlyingPhotog
Cream of the "Prop"
Mar 25, 2012 19:36 |  #6
If you're on a tripod, there's no reason to raise your ISO. Simply lengthen your shutter speed.
Jay
crn3371
Mar 25, 2012 19:37 |  #7
But in your example you stated you were using a tripod, so absolutely no need for high iso.
nate42nd
Mar 25, 2012 19:40 |  #8
Smaller aperture (Larger number) and more space between you and the target.
7D - - 17-55 F/2.8 - 24-105 F/4L - 100mm F/2.8 - 50mm F/1.8 - S95 / To see all click here
My Flickr (external link)
Ace ­ and ­ Deuce
Joined Feb 2012
Mar 25, 2012 19:44 |  #9
Ahhh, damn!! I was more worried about sharpness from the tripod and IS and never even thought about a longer shutter speed. Thanks bigtime guys! Trying to learn/remember one thing and I forgot about another, this gets confusing to me at times :( Unfortunately I'm all out of daylight, but I'm off tomorrow, so I'll have all day to play around.
Thanks again!!
Ace ­ and ­ Deuce
Joined Feb 2012
Mar 25, 2012 19:56 |  #10
kjonnnn wrote in post #14152426 (external link)
One thing you might want to consider in this case with the item sitting in the window is that it might be backlit in daylight, and be underexposed. Experiment, and use the manual setting instead of AV. Set the aperture and shutter according to the meter, and then adjust to shutter to OVER expose a bit so that the subject item isn't underexposed.
I was in manual mode...actually, I've yet to experiment with AV & TV mode.
oldvultureface
Gallery: 85 photos
Mar 25, 2012 19:57 |  #11
Ace and Deuce wrote in post #14152326 (external link)
Correct. That's the "exposure triangle". Closing your lens down from f/5.6 to f/8, you're letting in half the light. So either the shutter speed has to be lowered by half, i.e., 1/25, or the ISO has to be doubled to 1600. Going to f/11, half the light again, the shutter speed would be 1/13, or the ISO would be 3200 (at 1/50).
Ace ­ and ­ Deuce
Joined Feb 2012
Mar 25, 2012 20:04 |  #12
oldvultureface wrote in post #14152465 (external link)
This stuff is amazing (and fun) to learn! Thanks!
Albert ­ Nam
Joined May 2011
Mar 25, 2012 20:06 |  #13
If you back up and use a longer lens, you can get a nicely blurred background while still keeping your entire subject in focus.
Gear
JeffreyG
Gallery: 42 photos
Mar 25, 2012 20:08 |  #14
One other note. If you like that blurred background but want more DOF on the subject this is possible also. This is usually more applicable to portraiture, but here goes.
You can back up further from the subject and then use a longer focal length. If you stop down (use a smaller aperture) the DOF on the subject will increase, but the longer focal length with make the background blurrier.
So for example, 50mm and f/2 would give about the same background blur as 200mm and f/4 if you kept the framing the same (by moving back). But the longer lens would give more DOF due to using the smaller aperture.
oldvultureface
Gallery: 85 photos
Mar 25, 2012 20:20 as a reply to  @ JeffreyG's post |  #15
And see what focal length does to your background. Shoot the subject at 55mm. Then frame the subject at 18mm keeping its size the same in the viewfinder (hint: move closer). Note how the view of the background changes. Nice for including/excluding background details.
3,193 views & 0 likes for this thread, 15 members have posted to it.
DOF question/help
903 guests, 118 members online
