Thread started 27 Mar 2012 (Tuesday) 13:16
Dynalite MP800 Power Ratios
Village_Idiot
GREATEST POTN MEMBER EVER
Mar 27, 2012 13:16 |  #1
I'd like to make a cheat sheet for my lighting ratios like the Speedotron packs have painted on the side. Could someone tell me if this is correct and if it's not, what am I doing wrong?
Ch = Channel
A or B = Channel A or B
A1 or A2 = Socket 1 or 2 of Channel A
Please let me know if you can't view the Google Docs worksheet.
https://docs.google.co​m …FTR1F6azhtRlE&o​utput=html (external link)
My village called. I was told that they missed me.
Speedotron users, untie!
Wilt
Mar 27, 2012 23:40 |  #2
Not sure if I am reading your chart the way you intended. This seems to be wrong:
2 Lights A & B Ch Ratio'd
Each channel is independent of the other. So if both channels are at Full power with a single head in each channel, each head receives 400 w-s, not 200 w-s. If only a single head were plugged in to one of the channels, it would still receive 400 w-s.
And if two heads were plugged into ChA and one head plugged into ChB, each head in ChA gets 200 w-s at full power, while the head in ChB still gets 400 w-s.
Village_Idiot
Mar 28, 2012 09:10 |  #3
Wilt wrote in post #14166609 (external link)
I got the top part. Is the bottom with Ratio only? If it's combined with one in A and and 2 in B, it would be about 266w/s?
Thanks Wilt. You're my hero.
Wilt
Mar 28, 2012 10:08 |  #4
Village_Idiot wrote in post #14168097 (external link)
The last paragraph described the Ratio'd configuration. If the last configuration were Combined, three heads would equally divide 800 w-s at full power setting.
PacAce
Joined Feb 2003
Mar 28, 2012 11:23 |  #5
Village_Idiot wrote in post #14163171 (external link)
Ch = Channel
I could be way off base since I don't have a dynalite pack but based on other packs that I'm more familiar with (and making an educated guess), I think the power is distributed more like the following:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/03/4/LQ_587798.jpg
Image hosted by forum (587798) © PacAce [SHARE LINK]
Of course, this is assuming that the A or B power switch can be turned off completely. If not, then ignore that part of the chart where each is turned off (indicated by a dash "-").
...Leo
Wilt
Mar 28, 2012 11:32 |  #6
Leo's chart is correct!
Village_Idiot
Mar 28, 2012 12:19 |  #7
Thanks guys.
There was a brain fart on that one. I didn't realize that when combined, the toggle switched on both sides adjusted the power. /facepalm
So lowest power with two heads on 1 channel with the ratio setting and dialed down 2 stops with the variator would be 12.5. Not too shabby.
I'm looking at maybe a 400-500 w/s pack for my next one.
Mick.TheBrick
1 post
Joined Jun 2012
Jun 09, 2012 11:09 as a reply to  @ Village_Idiot's post |  #8
How about this folks?
IMAGE: http://share.clickerella.com/photos/i-8xfMvGS/0/M/i-8xfMvGS-M.jpg
Mick
2,816 views & 0 likes for this thread, 4 members have posted to it.
515 guests, 154 members online
