Thread started 27 Mar 2012 (Tuesday) 22:41
Question: Does flash bounced from a mirror trigger optical slaves?
shaker69
Mar 27, 2012 22:41 |  #1
Does flash bounced from a mirror... trigger optical slaves?
How about IR?
I tried to google it but can't find an answer, or I just don't know how to word it for search. lol
Thanks in advance.
7D/XTi/100 2.8/50 1.8/18-135/S30 1.4/T11-16 2.8/100-400L IS
sempaidavid
Mar 27, 2012 22:49 |  #2
yes and yes
5D mkIII, 1D mkIV, Tokina 16-28 f/2.8, EF 24-70L, EF 70-200 f/2.8L II IS, EF 100-400L, EF 85 f/1.8, Sigma 50 f/1.4, EF 24-105
http://www.davidcostap​hotography.com (external link)
shaker69
Mar 27, 2012 23:43 |  #3
sempaidavid wrote in post #14166450 (external link)
yes and yes
Thanks David!
OneJZsupra
Mar 28, 2012 09:55 |  #4
Correct
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
Village_Idiot
GREATEST POTN MEMBER EVER
Mar 28, 2012 13:37 |  #5
Unless...That mirror has a special light absorbing coating and then it wouldn't be less of a mirror.
My village called. I was told that they missed me.
Speedotron users, untie!
mikeca42
Joined May 2011
Mar 28, 2012 14:58 as a reply to  @ Village_Idiot's post |  #6
Flash bounced off walls and ceilings indoors will trigger an optical slave. Never tried a mirror, but must work.
HughR
Mar 28, 2012 15:15 |  #7
I've been using the pop-up flash on my 60D to trigger two 430EX and 430EX II for years. ETTL and triggering work perfectly indoors around corners with no line of sight due to reflections from walls, etc. And yes, you can use a mirror to go around corners if you want to.
Your 7D has the same wireless system and should work identically.
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
shaker69
Mar 29, 2012 03:05 |  #8
HughR wrote in post #14170126 (external link)
Thanks Hugh, mike, Village Idiot!
shaker69
Mar 29, 2012 03:07 |  #9
How about outdoors with direct line of sight to the mirror, no shade, sun at full blast noontime?
OneJZsupra
Mar 29, 2012 08:03 |  #10
Why not just get cheap triggers? Unless you are trying to shoot in ETTL
Numenorean
Mar 29, 2012 08:13 |  #11
If the flash shows up in the mirror in your shot, it will screw up your ETTL metering though.
1,880 views & 0 likes for this thread
Latest registered member is julia.signe
985 guests, 371 members online
