Thread started 28 Nov 2005 (Monday) 19:36
EOS 20D: Flash doesn't popup anymore
mkloiber
Joined Nov 2005
Nov 28, 2005 19:36 |  #1
The flash on my EOS 20D (2.0.3) doesn't popup anymore. Hear the clicking noises, but it fails to open. After the camera tries for a while, I get error 99. Anybody seen this?
Thanks for any feedback,
Martin
robertwgross
Joined Nov 2002
Nov 28, 2005 19:43 |  #2
Yes.
Search for the discussion within the last two months.
---Bob Gross---
mrclark321
Noinker
Nov 28, 2005 19:51 |  #3
Put the camera on "Man" Try pushing the flash button and if it does not open, lightly pry it open. Now keep press the flash button on the side and pry it open a few times then try just using the flash button to see if it opens by itself. Now pop and close the flash about 15 times and the problem will go away
Martin
Sony A7R3 & A7R4
Sony 16-35 GM
Sony 55mm 1.8
Batis 85mm
Sony 200-600
subtle_spectre
Nov 28, 2005 19:55 |  #4
A search will give you the answer in depth...essentially there is a mocro-switch under the rail of the hotshoe. It gets stuck in a depressed position causing the camera to "believe" an external flash is attached. The hotshoe can be romoved and the switch freed and voila! However, I would do the search to get all the details, many of which involve the same problem with my 20D.
Cheers!
Scott
Vista owner...and user  :p _______________
Gear
www.scottcphotography.​com (external link)
jediforce4ever
Joined Nov 2005
Nov 28, 2005 20:13 as a reply to  @ subtle_spectre's post |  #5
have you attached any external speedlights onto the camera?
~*~CanonGraphers~*~ (external link):D
mkloiber
Joined Nov 2005
Nov 29, 2005 11:29 |  #6
Thank you for all your feedback. I searched the forum for this issue and found some good advice. Seems that is a "standard" issue with the 20D's. I also see no reason to send it to Canon...I'll try the open/close routine. BTW, I don't think the hotshoe switch failed, because I can hear the lock happily click away. Seems to me the spring might not be strong enough or...the whole thing is just sticky and it's time to get the 580EX.....
Thanks,
Martin
wcapald
Joined Apr 2002
Nov 29, 2005 13:38 as a reply to  @ mkloiber's post |  #7
rub the contacts on the hot shoe, whilst pressing the flash release button on the side. I have an old 10D which used to suffer from the same problem... Wayne
Canon 5D, 20D, 10D, 350D
28-135USM IS Canon
28-105USM Canon
85mm Canon
20mm Sigma
Cassie
Gallery: 296 photos
Nov 29, 2005 15:05 as a reply to  @ mrclark321's post |  #8
This is exactly what I did;) I started having this same problem last week, but mine was 'err 05' I believe. But it seems to be working fine now:rolleyes:
http://thompson-photo.smugmug.com/ (external link)
https://instagram.com/​vegaquarium (external link)
Canon R
*EF 40 2.8*EF 50L*EF 135L*RF 50 1.8 STM* RF 24-105 F4 :D
430 EX II
Cassie
Gallery: 296 photos
Jan 06, 2006 11:01 |  #9
Err 05 is back!!
Every since attaching a canon remote a couple of days ago, I get 'err 05' everytime I try to use the flash. I've removed both batteries and tried all modes several times, with and without the remote, the only fix is to tap the flash a few times before hitting the flash pop up button :rolleyes: this has become really irritating :mad:
Just venting......
Canon R
430 EX II
Jon
Joined Jun 2004
Jan 06, 2006 12:36 |  #10
Take a look at this or this.
Jon
Cocker Spaniels
ScottE
Joined Oct 2004
Jan 06, 2006 12:42 |  #11
The pop up flash on my D60 hasn't been able to pop up for about four years. I've never bothered to have it fixed because an accessory flash does a much better job.
Mthorpe_Davies
Joined Apr 2004
Jan 06, 2006 13:24 |  #12
Now you have a good excuse to buy a 580ex or 430ex flash, the pop up flash is crap and a complete waste of time.
I take photos of stuff!
Cassie
Gallery: 296 photos
Jan 06, 2006 13:31 as a reply to  @ Jon's post |  #13
Thanks Jon. I missed the part about the hotshoe.......I'll check that, I've never had an external flash on the camera, must be some dirt, it's pretty ridiculous to have to tap the flash everytime I need to use it.
As sson as I recoup from the holidays I'll be getting the 580.
Thanks!
Canon R
430 EX II
RTMiller
Joined Dec 2004
Jan 06, 2006 13:39 as a reply to  @ Cassie's post |  #14
Take your hat off...
http://www.photography​-on-the.net/forum/showthre​ad.php?t=126118
Todd
www.PHOTODDGRAPHY.com (external link)
Equipment List
Everyone is beautiful if you squint.
Cassie
Gallery: 296 photos
Jan 06, 2006 15:36 as a reply to  @ RTMiller's post |  #15
Lol, that was pretty funny :p but I didn't have a hat on.....
Canon R
430 EX II
3,263 views & 0 likes for this thread, 11 members have posted to it.
1768 guests, 131 members online
