Thread started 28 Mar 2012 (Wednesday) 22:19
Sekonic L-358 PW Module will it work with PW TT5
kouasupra
Mar 28, 2012 22:19 |  #1
I know the pocket wizard module on the sekonic light meter will work with the older Plus II, but I'm not sure if it'll work on the new TT5 and TT1. I want to know before I buy the PW chip.
kouasupra
Mar 28, 2012 22:43 |  #2
Okay... Nevermind.. After some research it appears that it doesn't work with ETTL. You need to set it to Manual mode on the flash in order for it to work. PROBLEM SOLVED!
clarence
Mar 28, 2012 23:21 |  #3
http://www.sekonic.com​/Products/L-358/News.aspx (external link)
Sekonic Announces New Radio Transmitter Compatible with PocketWizard® ControlTL®
The new Sekonic RT-32CTL Radio Transmitter module will be [marker]available worldwide in April 2012[/marker]. The new Transmitter module provides compatibility with the PocketWizard® ControlTL® channels in addition to the original Standard channels. The RT-32CTL is offered as an optional plug-in accessory for the Sekonic L-358 FlashMaster, L-758D and L-758CINE, and built-in to the L-758DR DigitalMaster light meter. The RT-32CTL Radio Transmitter enables photographers for the first time, to[marker] trigger and measure flash output with the PocketWizard® FlexTT5 [/marker](Canon or Nikon) ControlTL® system in manual Power Control mode, as well as the PocketWizard® ST-4 and MC2 ControlTL® receivers. In addition, the new RT-32CTL fully supports the PocketWizard® PLUS series and MultiMAX receivers.
For Sale: 1D, T1i, 800mm, 600mm
5D3, 1D4, 7D, 600/4L, 200/1.8L, Sigmonster 300-800mm, 80-200/2.8L MDP, 28-70/2.8L, 85/1.8, 50/1.4, 12-24mm, (4) 550EXs, (4) WL strobes, PW MiniTT1/FlexTT5s/AC3/A​C9s
LoCo-Photo.com (external link)
kouasupra
Mar 29, 2012 00:02 |  #4
Great find! I'll be waiting for this module instead of buying the regular RT-32.
bobbyz
Mar 29, 2012 08:42 |  #5
Good news that the new radio modules will be avaialble soon. Big plus for PW system IMHO.
Fuji XT-1, 18-55mm
K.C.
Joined Jun 2010
Mar 29, 2012 22:18 |  #6
Now if they'd just add Profoto AIR it would be the only pro meter option on the market. So far the only manufacturer to add AIR compatibility is Hensel.
Toneaero
Apr 05, 2012 10:08 |  #7
If I'm only lighting with 1 580exii on manual power, do I even need this updated module? Speedlite is on flextt5 and camera has another flextt5 and ac3.
bobbyz
Apr 05, 2012 16:13 |  #8
Toneaero wrote in post #14214276 (external link)
If you want to meter, then yes.
Fuji XT-1, 18-55mm
kouasupra
Apr 05, 2012 19:37 |  #9
If your 580EXII is on manual the RT-32 chip will work just fine.
Toneaero
Apr 05, 2012 20:10 |  #10
Ok, help me understand why I wouldn't leave the 580exii on manual. Isnt that the reason why I would want to light meter it in the first place? If it was on ettl, then I wouldn't even need to meter because the camera would adjust the flash output for me. So in other words, what is the difference between Rt-32 vs RT-32CTL?
shmoogy
Apr 06, 2012 10:50 |  #11
Currently you need to switch to a non controltl channel, which is stupidly annoying. At least, I havent figured a way to maintain controltl and use the meter to fire triggers. It's a nuisance if you're controlling output with an ac3 as it only works on controltl channels.
5D Mark II, 35L, 24 TS-E, 50 1.8
Canon 1000D
bobbyz
Apr 06, 2012 17:31 |  #12
kouasupra wrote in post #14217020 (external link)
Nope if usung FlexTT5. 580ex is still in eTTL mode even though power is controlled manually by AC3.
Fuji XT-1, 18-55mm
bobbyz
Apr 06, 2012 17:33 |  #13
Toneaero wrote in post #14217176 (external link)
I thought you uisng AC3, FlexTT5 etc. Learn how they work. When AC3 in manual mode, your flash is still in eTTL mode except you can manually control power of the flash through that little wheel on your AC3. You can't trigger your flash (connected to FlexTT5) when using RT32 module on your PW.
Now if FlexTT5 was used as a dumb trigger in manual mode sure you can trigger through PW and RT32 but then you can't do anything through Ac3.
Fuji XT-1, 18-55mm
BamPhoto
May 21, 2012 10:31 |  #14
According to sekonic site, the new module will work with AC3 controller. You will need to update firmware thru usb, my 358 doesn't have usb???
Randy
My Gear List and Feedback
Website (external link)
BamPhoto
Jun 01, 2012 10:06 |  #15
And they only more than doubled the price of the other transmitter!! $149 at B\H
I think I see why most people don't use meters anymore.
Randy
5,567 views & 0 likes for this thread, 7 members have posted to it.
1451 guests, 127 members online
