Thread started 29 Mar 2012 (Thursday) 22:48
750watt/1000watt inverter for my lights
firme
Joined Mar 2012
Mar 29, 2012 22:48 |  #1
As I don't have at the moment to buy a power pack for my speedotron 1604 brown line I have been looking online for an inverter and came across some inverters that are 750watts and one that is 1000watts made by Peak and Duralast. These come with connectors that plug into your car battery (they look like jumper cables). I did see that it does say modified sine wave. I know it seems real tacky to use this but for $80-$100 I can use for the moment.
As it is not "portable" because I would not be able to take with me unless I unplug the battery from the car. But wanted to see if any one has used something similar or has known someone who has used one or simply knows if it will work or not.
Thank you for your help.
john ­ stakes
Mar 29, 2012 23:49 |  #2
If you are trying to build your own setup, you will need a pure sine wave inverter. I'm not sure what's offered but just google some DIY kits they are out there.
Canon 50D, T2i, 70-200 2.8L, kit lenses
My real name is Curtis. John Stakes is my old DBA.
[URL]Blogger[URL="http://www.cnote​vp.blogspot.com"]
K.C.
Joined Jun 2010
Mar 30, 2012 00:23 |  #3
Isn't this the same question you asked here ?
https://photography-on-the.net …/showthread.php​?t=1165457
firme
Joined Mar 2012
Mar 30, 2012 09:39 as a reply to  @ K.C.'s post |  #4
I apologize for that.
With these inverters I saw they have the cables attached, all you have to do is connect to the battery terminals as you would connect jumper cables to a car battery. So I don't need to purchase any additional cables. I tried contacting Speedotron to see what they say but no answer. I also saw other threads outside of here where modified sine waves worked with speedotron models. But they were from years back.
I did look up DIY on line which are not hard to find... but since I am not using the ones people actually used on their projects wanted to know if the ones I found will work with my speedotron.
Jofa
Joined Aug 2011
Mar 30, 2012 14:32 |  #5
If you buy an inverter, make sure that it's continuous power is enough AND that it's peak power output is WAY more than your flash needs. I've tried a 300W(contin., peak around 400-500w) and a 500w inverters connected to a car battery(car was running and at around 2500-3000 rpm, so the car charger voltage didn't drop, at least much, when charging the flash) with a 300ws (nameless brand) studio head and neither worked. I had modeling light(300w) turned off and flash at minimum output(for shorter charge time), but it took still way more power than either of those inverters could deliver.. I wish there was a cheap alternative but where I live, more powerful inverters are more than 400-500euros. :/
edit: I believe that most studio flashes have a quite high initial power(could be around 1-2kW for a little while, but still longer than what the "peak" power in inverters is meant for) because of how they are constructed. Might be that more expensive flashes have limited power intake and charge for a longer time but who knows..
Camera: 7D + Grip, Glass: Sigmas: 10-20mm f/3.5, 30mm f/1.4, 50mm f/1.4, 85mm f/1.4, 150mm f/2.8 OS. + light.
firme
Joined Mar 2012
Mar 30, 2012 15:37 |  #6
don't remember what the peak watt power it had but on the 1000 i believe if I remember right that its peak watt power was between 1500-2000.
so if the inverter does not work lets say if i purchase it... will it fry the speedotron or will it simply just not work?
alyson
Mar 31, 2012 03:19 |  #7
firme wrote in post #14180412 (external link)
Maybe because they can't recommend the readily available battery packs in the market for their Speedotrons.
Because for their Photogenics, they recommend other 3rd party battery pack.
(Btw, Speedotron has a new owner, PromarkBrands)
:cool: honesty is easy, fiction is where true genius lies :cool:
firme
Joined Mar 2012
Apr 02, 2012 09:00 |  #8
Alyson... yeah I was thinking the same. I guess as a business they want to be as careful what they recommend as they wouldn't want to be liable if something goes wrong. Also did not know they were owned by someone else.
Village_Idiot
GREATEST POTN MEMBER EVER
Apr 02, 2012 12:32 |  #9
john stakes wrote in post #14178822 (external link)
I've heard that the brown line speedos do not require a pure sine wave inverter.
My village called. I was told that they missed me.
Speedotron users, untie!
firme
Joined Mar 2012
Apr 02, 2012 13:40 |  #10
Yes... I have also read that on other forums.
I know DIY projects is at the person's own risk but just wanted to see if worst case scenario if the speedotron will actually malfunction in some way or will it just not simply work. But it seems that I will have to try the DIY. If I had the money I would have bought the Tronix Mini.
2,020 views & 0 likes for this thread
Latest registered member is LaurensW
657 guests, 302 members online
