Thread started 30 Mar 2012 (Friday) 18:02
shot today
torkk
Mar 30, 2012 18:02 |  #1
100%crop with my 55/250 bird was maybe about 50' away. Im thinking the ISO was set too high
IMAGE: http://i100.photobucket.com/albums/m12/Torkk/starling.jpg
Canon R10 , Canon RF 100-400
EnfieldRyder
Joined Sep 2011
Mar 31, 2012 00:16 |  #2
Could you post the EXIF info here? I just want to know what settings were used to capture this?
|Raghu| My Ride --> EOS 550D, 18-55mm Kit Lens, EF 50mm F1.8, EFs 55-250 IS, EFS 24mm F2.8 STM
MesserschmittMan
Joined Nov 2011
Mar 31, 2012 00:43 |  #3
ISO 400 ain't that high.
Canon 7D | Canon 10-22mm f/3.5-4.5 | Canon 50mm f/1.4 | Canon 70-200mm f4 IS L
andrew_patterson
Mar 31, 2012 00:55 |  #4
It's the crop. A 100% crop on a rebel body through the 55-250 isn't gonna look good, even if it was ISO 100, to get a nice crisp image, you're gonna have to just get closer so you don't have to crop.
Canon T1i/500D
EF-S 18-55 IS
EF-S 55-250 IS
AlienBees AB800 (x2)
justinz850
Joined Apr 2011
Mar 31, 2012 00:58 |  #5
You should move closer if your focus point is bigger than the bird :D
Canon 5D3
Leica M
Rolleiflex 3.5f
Titus213
Mar 31, 2012 01:38 |  #6
What have you done besides cropping?
A little noise reduction, and a little sharpening help I think.
Dave
Perspiring photographer.
SkyBaby
Gallery: 21 photos
Mar 31, 2012 01:52 |  #7
To my eye, thats pretty impressive for a crop from the long end.
~Kira~
Check out my Flickr for lots of aviation and nature related photography: http://www.flickr.com/​photos/skys_flickr/
Check out my Facebook fan page for my best of the best imagery. Give it a thumbs up if you like what you see! https://www.facebook.c​om/PhotographybyKiraAn​dreola (external link)
Bikervon
Gallery: 38 photos
Joined Sep 2011
Mar 31, 2012 12:19 |  #8
SkyBaby wrote in post #14184846 (external link)
I was thinking that too... good focus also.
Just getting back into it..
Canon T3i/nifty 50// 55-250IS/10-18mmIS/28-135IS/elph320HS & a few other bits
My Flickr (external link)
torkk
Mar 31, 2012 17:15 |  #9
---- ExifTool ----
ExifTool Version Number : 8.85
---- System ----
File Name : starling.jpg
Directory : C:/Users/JP/Desktop
File Size : 219 kB
File Modification Date/Time : 2012:03:30 18:58:13-04:00
File Permissions : rw-rw-rw-
---- File ----
File Type : JPEG
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Current IPTC Digest : cbf54d7e66beb074f89b44​39a13d738a
Image Width : 873
Image Height : 655
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:4:4 (1 1)
---- IFD0 ----
Make : Canon
Camera Model Name : Canon EOS DIGITAL REBEL XT
Orientation : Horizontal (normal)
X Resolution : 240
Y Resolution : 240
Resolution Unit : inches
Software : Adobe Photoshop CS5 Windows
Modify Date : 2012:03:30 18:58:06
Artist : unknown
---- ExifIFD ----
Exposure Time : 1/1600
F Number : 8.0
Exposure Program : Aperture-priority AE
ISO : 400
Exif Version : 0221
Date/Time Original : 2012:03:30 09:05:54
Create Date : 2012:03:30 09:05:54
Shutter Speed Value : 1/1600
Aperture Value : 8.0
Exposure Compensation : 0
Max Aperture Value : 1.8
Metering Mode : Multi-segment
Flash : Off, Did not fire
Focal Length : 250.0 mm
Color Space : Uncalibrated
Exif Image Width : 873
Exif Image Height : 655
Focal Plane X Resolution : 3954.23341
Focal Plane Y Resolution : 3958.762887
Focal Plane Resolution Unit : inches
Custom Rendered : Normal
Exposure Mode : Auto
White Balance : Manual
Scene Capture Type : Standard
---- IFD1 ----
Compression : JPEG (old-style)
X Resolution : 72
Y Resolution : 72
Thumbnail Offset : 754
Thumbnail Length : 5010
---- IPTC ----
Coded Character Set : UTF8
Application Record Version : 9856
By-line : unknown
Date Created : 2012:03:30
Time Created : 09:05:54
---- Photoshop ----
Photoshop 0x043a : ...printOutput.ClrSenu​mClrSRG[...]
Photoshop 0x043b : ...printOutputOptions.​CptnboolCl[...]
X Resolution : 240
Displayed Units X : inches
Y Resolution : 240
Displayed Units Y : inches
Print Scale : ?€
Global Angle : 30
Global Altitude : 30
Print Flags : .
Print Flags Info : ..
Color Halftoning Info : /ff.lff../ff.¡™š..2.Z.​.5.-..
Color Transfer Funcs : ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ​.èÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ​ÿÿ.èÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ​ÿÿÿÿ.èÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ​ÿÿÿÿÿÿ.è
Grid Guides Info : ..@.@
URL List :
Slices : ...i.IMG_0120...i....null..boundsObjc.Rct1.Top longLeftlongBtomlong.Rghtlong.i.slicesVlLs.Objc..slice..sliceIDlong.groupIDlong.originenum.ESliceOrigin.autoGeneratedTypeenum.ESliceTypeImg .boundsObjc.Rct1.Top longLeftlongBtomlong.Rghtlong.i.urlTEXT.nullTEXT.MsgeTEXT..altTagTEXT..cellTextIsHTMLbool..cellTextTEXT..horzAlignenum.ESliceHorzAlign.default.vertAlignenum.ESliceVertAlign.default.bgColorTypeenum.ESliceBGColorTypeNone.topOutsetlong.leftOutsetlong.bottomOutsetlong.rightOutsetlong
Pixel Aspect Ratio : .?ð
IDs Base Value : .
Photoshop Thumbnail : (Binary data 5010 bytes, use -b option to extract)
Version Info : ...Adobe Photoshop.Adobe Photoshop CS5.
Photoshop Quality : 10
Photoshop Format : Standard
Progressive Scans : 3 Scans
---- XMP-x ----
XMP Toolkit : Adobe XMP Core 5.0-c060 61.134777, 2010/02/12-17:32:00
---- XMP-xmp ----
Modify Date : 2012:03:30 18:58:06-04:00
Create Date : 2012:03:30 09:05:54-04:00
Rating : 0
Metadata Date : 2012:03:30 18:58:06-04:00
---- XMP-dc ----
Format : image/jpeg
Creator : unknown
---- XMP-aux ----
Serial Number : 1720740773
Lens Info : 55-250mm f/?
Lens : 55.0-250.0 mm
Lens ID : 65535
Image Number : 120
Flash Compensation : 0
Owner Name : unknown
Firmware : 1.0.3
---- XMP-crs ----
Raw File Name : IMG_0120.CR2
Version : 6.0
Process Version : 5.7
White Balance : As Shot
Color Temperature : 6850
Tint : +6
Exposure : 0.00
Shadows : 5
Brightness : +50
Contrast : +25
Saturation : 0
Sharpness : 25
Luminance Smoothing : 0
Color Noise Reduction : 25
Chromatic Aberration R : 0
Chromatic Aberration B : 0
Vignette Amount : 0
Shadow Tint : 0
Red Hue : 0
Red Saturation : 0
Green Hue : 0
Green Saturation : 0
Blue Hue : 0
Blue Saturation : 0
Fill Light : 0
Vibrance : 0
Highlight Recovery : 0
Clarity : 0
Defringe : 0
Hue Adjustment Red : 0
Hue Adjustment Orange : 0
Hue Adjustment Yellow : 0
Hue Adjustment Green : 0
Hue Adjustment Aqua : 0
Hue Adjustment Blue : 0
Hue Adjustment Purple : 0
Hue Adjustment Magenta : 0
Saturation Adjustment Red : 0
Saturation Adjustment Orange : 0
Saturation Adjustment Yellow : 0
Saturation Adjustment Green : 0
Saturation Adjustment Aqua : 0
Saturation Adjustment Blue : 0
Saturation Adjustment Purple : 0
Saturation Adjustment Magenta : 0
Luminance Adjustment Red : 0
Luminance Adjustment Orange : 0
Luminance Adjustment Yellow : 0
Luminance Adjustment Green : 0
Luminance Adjustment Aqua : 0
Luminance Adjustment Blue : 0
Luminance Adjustment Purple : 0
Luminance Adjustment Magenta : 0
Split Toning Shadow Hue : 0
Split Toning Shadow Saturation : 0
Split Toning Highlight Hue : 0
Split Toning Highlight Saturation: 0
Split Toning Balance : 0
Parametric Shadows : 0
Parametric Darks : 0
Parametric Lights : 0
Parametric Highlights : 0
Parametric Shadow Split : 25
Parametric Midtone Split : 50
Parametric Highlight Split : 75
Sharpen Radius : +1.0
Sharpen Detail : 25
Sharpen Edge Masking : 0
Post Crop Vignette Amount : 0
Grain Amount : 0
Color Noise Reduction Detail : 50
Convert To Grayscale : False
Tone Curve Name : Medium Contrast
Camera Profile : Adobe Standard
Camera Profile Digest : 076EB93F90F85BD4B92966​55584B5D05
Has Settings : True
Crop Top : 0.38501
Crop Left : 0.444824
Crop Bottom : 0.544922
Crop Right : 0.586968
Crop Angle : 0
Crop Width : 3
Crop Height : 4
Crop Unit : Unknown (3)
Has Crop : True
Already Applied : True
Tone Curve : 0, 0, 32, 22, 64, 56, 128, 128, 192, 196, 255, 255
---- XMP-photoshop ----
Sidecar For Extension : CR2
Color Mode : RGB
ICC Profile Name : Adobe RGB (1998)
Date Created : 2012:03:30 09:05:54
---- XMP-xmpMM ----
Instance ID : xmp.iid:77EE14D0BB7AE1​11B0FCB4D63A2C7A41
Document ID : xmp.did:76EE14D0BB7AE1​11B0FCB4D63A2C7A41
Original Document ID : xmp.did:76EE14D0BB7AE1​11B0FCB4D63A2C7A41
History Action : saved, converted, derived, saved
History Instance ID : xmp.iid:76EE14D0BB7AE1​11B0FCB4D63A2C7A41, xmp.iid:77EE14D0BB7AE1​11B0FCB4D63A2C7A41
History When : 2012:03:30 18:58:06-04:00, 2012:03:30 18:58:06-04:00
History Software Agent : Adobe Photoshop CS5 Windows, Adobe Photoshop CS5 Windows
History Changed : /, /
History Parameters : from image/tiff to image/jpeg, converted from image/tiff to image/jpeg
Derived From Instance ID : xmp.iid:76EE14D0BB7AE1​11B0FCB4D63A2C7A41
Derived From Document ID : xmp.did:76EE14D0BB7AE1​11B0FCB4D63A2C7A41
Derived From Original Document ID: xmp.did:76EE14D0BB7AE1​11B0FCB4D63A2C7A41
---- ICC-header ----
Profile CMM Type : ADBE
Profile Version : 2.1.0
Profile Class : Display Device Profile
Color Space Data : RGB
Profile Connection Space : XYZ
Profile Date Time : 1999:06:03 00:00:00
Profile File Signature : acsp
Primary Platform : Apple Computer Inc.
CMM Flags : Not Embedded, Independent
Device Manufacturer : none
Device Model :
Device Attributes : Reflective, Glossy, Positive, Color
Rendering Intent : Perceptual
Connection Space Illuminant : 0.9642 1 0.82491
Profile Creator : ADBE
Profile ID : 0
---- ICC_Profile ----
Profile Copyright : Copyright 1999 Adobe Systems Incorporated
Profile Description : Adobe RGB (1998)
Media White Point : 0.95045 1 1.08905
Media Black Point : 0 0 0
Red Tone Reproduction Curve : (Binary data 14 bytes, use -b option to extract)
Green Tone Reproduction Curve : (Binary data 14 bytes, use -b option to extract)
Blue Tone Reproduction Curve : (Binary data 14 bytes, use -b option to extract)
Red Matrix Column : 0.60974 0.31111 0.01947
Green Matrix Column : 0.20528 0.62567 0.06087
Blue Matrix Column : 0.14919 0.06322 0.74457
---- Adobe ----
DCT Encode Version : 100
APP14 Flags 0 : [14]
APP14 Flags 1 : (none)
Color Transform : YCbCr
---- Composite ----
Aperture : 8.0
Date/Time Created : 2012:03:30 09:05:54
Image Size : 873x655
Scale Factor To 35 mm Equivalent: 6.2
Shutter Speed : 1/1600
Thumbnail Image : (Binary data 5010 bytes, use -b option to extract)
Circle Of Confusion : 0.005 mm
Field Of View : 1.3 deg
Focal Length : 250.0 mm (35 mm equivalent: 1543.5 mm)
Hyperfocal Distance : 1605.37 m
Lens ID : Unknown (65535) 55-250mm
Light Value : 14.6
mattmorgan44
Joined Feb 2012
Mar 31, 2012 21:33 |  #10
torkk wrote in post #14187637 (external link)
---- ExifIFD ----
F Number : 8.0
ISO : 400
Exif Version : 0221
That's a whoooole lot of Exif info. If this is the 55-250 why does it say Max Aperture Value: 1.8?
5D Mark II | 7D
24L II | 50L | 100L Macro
Some other stuff
Can't find a Lee filter holder? - Cokin Modification for wide angle lenses
torkk
Mar 31, 2012 21:34 |  #11
dunno what should it be
mattmorgan44
Joined Feb 2012
Mar 31, 2012 21:59 |  #12
I would have assumed f/5.6, or at least f/4.0
5D Mark II | 7D
Some other stuff
andrew_patterson
Apr 01, 2012 16:30 |  #13
Yeah if it was the 55-250 it couldn't be 1.8.
EDIT: Seems like some sort of bug in recording the EXIF data correctly.
Canon T1i/500D
EF-S 18-55 IS
EF-S 55-250 IS
torkk
Apr 01, 2012 18:30 as a reply to  @ andrew_patterson's post |  #14
Make : Canon
X Resolution : 72
Y Resolution : 72
Modify Date : 2012:04:01 15:41:32
Artist : unknown
---- ExifIFD ----
Exposure Time : 1/400
F Number : 7.1
ISO : 200
Exif Version : 0221
Date/Time Original : 2012:04:01 13:03:03
Create Date : 2012:04:01 13:03:03
Shutter Speed Value : 1/400
Aperture Value : 7.1
Exif Image Width : 1843
Exif Image Height : 1229
HTTP response: 400 | MIME changed to 'text/html'
Titus213
Apr 01, 2012 21:03 |  #15
I would expect the problem is not with the exif but rather the exif tool software.
Although my exif viewer is reporting the same max f-stop. It just doesn't report as much information.
Dave
2,304 views & 0 likes for this thread, 9 members have posted to it.
shot today
1119 guests, 133 members online
