Thread started 31 Mar 2012 (Saturday) 09:40
Questions on FoCal AF Micro Adjustment Calibration
mrmarks
Mar 31, 2012 09:40 |  #1
How reliable and accurate is FoCal? How easy is it to do the calibration setup? Which is recommended - Focal Plus or Focal Pro? I am currently using this method http://www.northlight-images.co.uk …s3_af_micoadjus​tment.html (external link) and wonder if the FoCal is worth it? Thanks for the inputs
rdalrt
Mar 31, 2012 10:23 |  #2
I use FoCal Pro. Very easy to setup and use and a great time saver. I have 4 bodies and 8 lenses. I was able to MA all of them in a day doing multiple trials with each body and lens.
I have noticed an improvement in the sharpness of my pics since doing the MA. So, for me it was definitely worth it.
Just Sports Photographyexternal link
My Junk ;)
mrmarks
Mar 31, 2012 10:28 |  #3
rdalrt, do you need to change the distance between the chart and the camera according to the focal length? Thanks
rdalrt
Mar 31, 2012 10:35 |  #4
Well, you don't have to, but it is recommended to use the 50x focal length rule. I just started with the shortest focal length lenses and kept backing up as I went. The distance doesn't have to be exact. Or you can even use the distance you usually shoot a lens at.
My Junk ;)
mrmarks
Mar 31, 2012 10:41 |  #5
I see a few different chart types for FoCal. How do you use them?
jrsforums
Mar 31, 2012 10:54 |  #6
mrmarks wrote in post #14186090 (external link)
Suggest you read the instructions...
John
similae
Joined May 2011
Mar 31, 2012 13:16 |  #7
I have the semi-automatic version, and I would recommend getting at least the PLUS-version. In my opinion semi-automatic has no advantages over doing it manually with normal printed test chart. My results were the same (which is good) and took the same amount of time to achieve it in both ways.
I'm only disappointed I went for the cheaper version, wrong place to save! (again.. ;) )
Mikko
6D, EF 50 f/1.4, EF 200mm f/2.8 L II, Nissin Di622 Mark II
hollis_f
Apr 01, 2012 05:52 |  #8
  • Version? Plus or Pro. Like Mikko says, fully automatic really is worth the extra.
  • Target? A suitable target for you to print out is included in the package. I stuck mine to some foam-core board for stability.
  • Distance? I started with my 300mm + 2xTC and put the target across the garden. Only 20x focal length, but it was all I could manage. As I went down in focal length I moved the target (mounted on a second tripod) closer.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
avan
Sep 25, 2012 10:12 |  #9
similae wrote in post #14186675 (external link)
I know it's late, but good to know:
From Raikan Focal site:
Can I upgrade?
Of course. There is no upgrade fee other than the price difference between the versions. So, for example, if you purchase a license for the Standard version, and after using it you decide you would like to upgrade to the Pro version, you simply pay the difference and Reikan will supply you with a new license enabling the Pro version features.
You can do this from our License Management System.
1DMK4, T6s, 100-400mmL IS II, 16-35mm f4, 100mm macro
[www.pbase.com/jeelee/g​alleries (external link)
2,848 views & 0 likes for this thread, 6 members have posted to it.
1470 guests, 131 members online
