Thread started 31 Mar 2012 (Saturday) 15:30
Canon 40D and soccer shots
Donnieboy
Joined Mar 2012
Mar 31, 2012 15:30 |  #1
Hi Guys/Gals,
I'm new here and yes this is my first post. I thought this would be the best place to post this question and ask for help.
I have recently been given a Canon 40D. Hardly used. Only 3500 shots. A brand new 28-135 Canon lens and some other goodies.
I am trying to capture my kids playing soccer but its coming up blurry.
Can someone please help me out here?
What settings should I be at or have it on?
AI Servo or AI Focus?
Please if someone could point me in the right direction/step by step outline to help me out it would be awesome.
I want to capture them moving, I.e. shooting at the net etc...but everytime I can't figure it out, it always comes out blurry.
Thank you.
watt100
Mar 31, 2012 15:45 |  #2
Donnieboy wrote in post #14187251 (external link)
Hi Guys/Gals,
Thank you.
AI servo but chances are your shutter speed is too low, post a pic.
the faster the shutter speed the sharper the shots
XSi (450D)
Canon 55-250IS
1/1000 shutter speed
IMAGE: http://farm5.staticflickr.com/4148/5094738512_36a2d67e79_z.jpg
Donnieboy
Joined Mar 2012
Mar 31, 2012 15:48 |  #3
Thanks for the reply.
Don't have a pic on me. But if I can explain in words, its BLURRY.
I need to learn how to play with the ISO for sure as well then it sounds in order to get the lighting and shutter speed faster.
What is the ball park shutter speed I should be using you think?
watt100
Mar 31, 2012 15:53 |  #4
Donnieboy wrote in post #14187317 (external link)
at least 1/1000, preferably higher. increase the ISO to 400 or whatever it takes to get a fast shutter speed to freeze the action
stock28
Gallery: 6 photos
Mar 31, 2012 23:17 |  #5
As others have said, you should be at least 1/1000. Use as shallow depth of field as your lens will give you and adjust iso as needed. AI servo is also your best bet at following the action.
7D, 70-200 L f4 non IS, 100 macro 2.8, 50 1.8, 18-55 kit
FlickR (external link)
Tiberius
Mar 31, 2012 23:25 |  #6
There are different kinds of blur. One kind is caused by camera shake. Or it could be because the subject is moving during the exposure. Or maybe it is a focus issue.
You should try putting your camera into TV mode, set a shutter speed of at least 1/1000. You may need to increase your aperture a bit.
My photography website!PHOCAL PHOTOGRAPHY (external link)
shutterpat
Gallery: 33 photos
Best ofs: 11
Mar 31, 2012 23:54 |  #7
When it's sunny & bright I shoot with AV mode @ wide open, metering mode @ multi-segment and ISO at 100-200. My camera settings are AF servo on Hi-speed continuous and center point focus.
Offense... (external link) by OC PAT (external link), on Flickr
Mid Air.... (external link) by OC PAT (external link), on Flickr
Ouch... (external link) by OC PAT (external link), on Flickr
...and when it's cloudy/overcast I shoot on manual mode @ wide open using center weighted as my metering mode.
IMG_2511 (external link) by OC PAT (external link), on Flickr
IMG_2455 (external link) by OC PAT (external link), on Flickr
IMG_2533 (external link) by OC PAT (external link), on Flickr
I normally position myself at the right side of the end zone. Watch your horizon and use the vertical position to get those tight action shots. I'm no pro just sharin' you what I do when shooting soccer games. Hope this helps.
Mike414
Apr 01, 2012 01:28 as a reply to  @ shutterpat's post |  #8
Here is some soccer with my 40D and 70-200
Manual at 2.8 with the sun behind me.
What seems to work for me is that I always sit as low as I can to get the best results.
IMAGE: http://i384.photobucket.com/albums/oo289/CanonDigitals/d-9.jpg
IMAGE: http://i384.photobucket.com/albums/oo289/CanonDigitals/c-9.jpg
IMAGE: http://i384.photobucket.com/albums/oo289/CanonDigitals/b-8.jpg
IMAGE: http://i384.photobucket.com/albums/oo289/CanonDigitals/a-9.jpg
IMAGE: http://i384.photobucket.com/albums/oo289/CanonDigitals/f-7.jpg
g/l
Mike
My Stuff:
40D - 70-200mm f/2.8L IS - 17-55mm f/2.8 IS - Speedlite 430EX - Rebel XT - 18-55mm f/3.5-5.6 - 50mm f/1.8 -Monopod - Tripod.
"How old would you be if you didn't know how old you were ?"
1,980 views & 0 likes for this thread, 6 members have posted to it.
2226 guests, 130 members online
