Hey guys and gals,
in LR4 under soft proofing there's an option for Color Space profile, what's the best option for this AdobeRGB1998 or sRGB?
rickp1 Senior Member 513 posts Joined Apr 2009 More info | Apr 01, 2012 12:48 | #1 Hey guys and gals, Canon 5DMkII | 70-200mm f2.8 IS USM | 24-105mm f4.0 IS USM | 85mm f1.8 prime.
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Apr 01, 2012 17:03 | #2 Soft proofing is a preview of how your image will look after it is exported in a particular space or more importantly how it will look printed. This being so, it only makes sense to soft proof to the same space in which you will be exporting. So your question becomes the more important one, "What's the best option for an export space?" The answer is determined by what you intend to do with the image. For web posting, emailing/MSMing or having prints made by a commercial lab, it is important to use sRGB. For home printing with a good quality inkjet (6 or more ink colors) or for lithographic press, choose Adobe RGB (although if the printer is at home it makes more sense to print directly from LR in the printer's space without exporting (saving) a rendered image.) Elie / אלי
tonylong ...winded More info | Apr 01, 2012 18:06 | #3 So I haven't gotten and installed LR4 yet (any day now) but Elie, is it true then that the SoftProofing includes Color Space softproofing in the way that you can do with DPP and ACR? It sounds like it does, which is a good thing Tony
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Apr 02, 2012 04:56 | #4 tonylong wrote in post #14192433 So I haven't gotten and installed LR4 yet (any day now) but Elie, is it true then that the SoftProofing includes Color Space softproofing in the way that you can do with DPP and ACR? It sounds like it does, which is a good thing !Yes it does, but whereas ACR can only show three output spaces and DPP four, LR can use any RGB space that you have the profile for, so if you're into Chrome 2000 D65 RGB you can soft proof it. It also has an Out Of Gamut alarm overlay that can be turned on. As an added bonus the probe numbers under the histogram change from percentages to 0-255 scale values. (It took me years to get used to the percentages and I'm still not comfortable with them.) Elie / אלי
| Latest registered member is Frankie Frankenberry 1069 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
