Thread started 01 Apr 2012 (Sunday) 19:39
inconsistent (maybe) second curtain sync
ncjohn
Apr 01, 2012 19:39 |  #1
I wanted to do a little experimenting with 2nd curtain flash sync, so i set up a teddy bear in the sun room and did some portraits, some with 1st curtain sync and some with 2nd. I compared the results in DPP, using the "info" box to show me which photo was made with which curtain. No problems. Then I left the camera in 2nd curtain sync (intentionally) and did some shots of my wife but when I checked the results in DPP, all the shots showed to have been made with 1st curtain sync. I thought, man, that was careless, but when I checked the camera it was still set to 2nd curtain, the way I left it. So I just scratched my head and wondered what had happened.
Today I went out to do some playing with 2nd curtain sync and leaves blowing in the breeze.When I checked the shots, DPP showed all of them to have been made in 1st curtain. Like before, I check the camera and it's still set to 2nd curtain. At this point I'm sure the camera's acting up, so I just fired off 2 shots, one set to 1st curtain and the next to 2nd curtain, because I'm sure they're both going to show 1st curtain, but they didn't. The one I shot set to 1st curtain showed that way, and the one I shot set to 2nd curtain showed that way.
Has anybody heard of this?
ncjohn
Apr 01, 2012 20:16 |  #2
I can't really see why it matters, but it's a 450D (Rebel XSi) using the on-camera flash. I've also done a bunch more test shots, and DPP identified the correct curtain each time.
theatrus
Apr 01, 2012 23:21 |  #3
Your shutter speed is still within sync range?
5Dc, 5D III, 24-70L, 17-40L, 24-105L, 70-200 f/4L, 100 macro, 135L, 50 1.4 | NEC LCD3090
ncjohn
Apr 01, 2012 23:33 |  #4
theatrus wrote in post #14194144 (external link)
Yeah, actually, the camera won't allow you to raise it above 200, which is the highest sync speed for the 450D.
AntonLargiader
Apr 02, 2012 06:26 |  #5
What camera and what flash?
With some settings (like FEC), the one made on the flash will override the one made on the camera.
Image editing and C&C always OK
Gear list plus: EF 1.4X II . TT1/TT5 . Bogen/Manfrotto 3021 w/3265 ball-mount
bsmotril
Gallery: 11 photos
Joined Feb 2006
Apr 02, 2012 09:20 |  #6
2nd curtain sync only works below a certain threshold shutter speed, it differs for various camera models. Check your manual, it will say what it is for your camera. Maybe you had a shutter speed set above that threshold.
Galleries: http://www.flickr.com/​photos/smopho/ (external link) --- http://billsmotrilla.z​enfolio.com/ (external link)
ncjohn
Apr 02, 2012 09:47 |  #7
bsmotril wrote in post #14195815 (external link)
The manual only says, "slow shutter speeds" but I just ran a little test and you're right; looks like the cut-off point is 1/30 sec.
thanks a lot.
1,594 views & 0 likes for this thread, 4 members have posted to it.
1057 guests, 103 members online
