Thread started 02 Apr 2012 (Monday) 08:38
Which lens has better IQ - 17-40L or 24-105L?
dkizzle
Joined Mar 2012
Apr 02, 2012 08:38 |  #1
Which one is better from 24-40 on FF?
I want to guest blog on your Landscape / Travel photography blog, PM for details
rick_reno
Apr 02, 2012 09:56 |  #2
your mileage may vary with the lens you get, but i've found the 17-40 to be better.
dkizzle
Joined Mar 2012
Apr 02, 2012 10:53 |  #3
I have 24-105 already and plan on borrowing 17-40 from a friend for my trip. I would only use it for wide shots and it would be 17-30mm range. For anything else I will use my 24-105 which will have Singh-Ray Vari-n-Trio :)
ejenner
Gallery: 98 photos
Joined Nov 2011
Apr 02, 2012 13:13 as a reply to  @ dkizzle's post |  #4
17-40. They both take the same filter size and I use the 17-40 for all overlapping FL if I can. The difference isn't massive but enough to prefer the 17-40.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
paulkaye
Joined Nov 2010
Apr 02, 2012 16:55 |  #5
I've got both on a 5dii and this is my view:
- The 17-40 is sharper in the centre wide open.
- The 24-105 is sharper in the corners wide open.
- Stopped down the 17-40 is sharper across the frame.
- CA control is better on the 17-40.
- I think colour rendition is better on the 17-40.
So, on balance I reckon the 17-40 is the better lens optically, but the 24-105 is no slouch, has IS and covers a very useful range of focal lengths.
Paul
5DII, 50mm 1.4, 17-40L, 85mm 1.8, 24-105L IS, 70-200L f4 IS, 100-400L, 100 f2.8 Macro
dkizzle
Joined Mar 2012
Apr 02, 2012 18:28 |  #6
@paul
Thanks for this info. I was originally planning on using 24-105mm for most of the shots with V-n-T and keeping 17-40 just for the wide shots with UV filter. Since V-n-T is a triple filter its thicker and causes vignetting at wide side. From my reading on this forum I will be using it closer to 30mm to be safe, maybe as low as 28mm.
1,752 views & 0 likes for this thread, 4 members have posted to it.
Latest registered member is finnianmarlowe
1338 guests, 176 members online
