I bought a used 100-400mm and I was wondering how old it is but it has no date code.
All it has is numbers on the barrel near the mount end, It has 225024 anyone know how old this is from these numbers.
BlackBart Member 241 posts Likes: 15 Joined Aug 2009 More info | Apr 02, 2012 17:01 | #1 I bought a used 100-400mm and I was wondering how old it is but it has no date code.
Invertalon Cream of the Crop 6,495 posts Likes: 24 Joined Jun 2009 Location: Cleveland, OH More info | Apr 02, 2012 17:43 | #2 |
Apr 02, 2012 18:09 | #3 Invertalon wrote in post #14198641 It may of had a repair done that removed the original baffle at the end of the lens that had the age possibly. I have seen a few repaired lenses that had the original baffle removed with one with no date code. Could be why. Do you have any idea what those numbers mean on the barrel 225024
msowsun "approx 8mm" More info | Apr 02, 2012 19:40 | #5 This same question came up recently with a 70-200mm f/4.0 Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Apr 03, 2012 07:38 | #6 msowsun wrote in post #14199309 This same question came up recently with a 70-200mm f/4.0 Sometimes they are hard to see.... You have to look VERY carefully..... But 100-400mm date codes are usually printed on so it should be more visible. 70-200 f4 ![]() ![]() Thanks Mike I used a magnifying glass and found it.
msowsun "approx 8mm" More info | Apr 03, 2012 07:57 | #7 Why was it so hard to see? Was it stamped into the plastic like the example above, or was it printed? Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
alpha_1976 Goldmember 3,961 posts Likes: 1 Joined Nov 2009 Location: USA More info | Apr 03, 2012 08:21 | #8 It's printed on the one that I have. I know more about gear than I know about photography
DavidE Member 131 posts Joined Jun 2008 More info | Mike, you're the man! My prob was the reverse, 100-400 date code clearly visible, 70-200 I had struggles with. 40 D, Canon 10-22, 18-55 IS, 50 f1.8, 85 f1.8, 70-200 f4, L, 100-400 L, 430 EXII
Apr 03, 2012 15:28 | #10 msowsun wrote in post #14201755 Why was it so hard to see? Was it stamped into the plastic like the example above, or was it printed? Badly worn and hard to see.
| Latest registered member is Monkeytoes 1497 guests, 186 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
