Thread started 03 Apr 2012 (Tuesday) 09:26
NOOB flash
Haswell
Joined Oct 2011
Apr 03, 2012 09:26 |  #1
Hello, I wonder if you can give me advice on the following equipment:
I have a 60D and a 430II flashgun which i can fire wireless using the built in flash. Where is the optimum position for the 430 if Im taking a portrait? What settings should I use? Do I need to use any gizmos to soften/bounce the light?
I realise I might be asking how long is a piece of string but any opening remarks would be well appreciated.
Many thanks.
Drinking alcohol never solves anything. But neither does drinking milk.
DHPHOTO66
Joined Jan 2012
Apr 03, 2012 09:42 |  #2
Haswell wrote in post #14202183 (external link)
Many thanks.
This may be helpful: http://www.youtube.com​/watch?v=j5guFQNBToQ (external link)
Uncle Donn | http://www.flickr.com/​photos/dhphoto66/ (external link)
Haswell
Joined Oct 2011
Apr 03, 2012 09:52 as a reply to  @ DHPHOTO66's post |  #3
Thank you, that was interesting.
alduin
Apr 03, 2012 09:55 |  #4
From the stickies:
ETTL Wireless Config: Part I - Working with a single remote flash
7D+BG-E7 | 5D | G9 | 24-70 f/2.8L | 70-200 f/2.8L IS | 100-400L IS | 10-22mm | 50mm f/1.4 | 580EX II | 430EX II | YN565EX
Manfrotto 055XPROB/488RC2 | 680B/234RC
Haswell
Joined Oct 2011
Apr 03, 2012 11:04 |  #5
Thank you that was helpful
RPCrowe
Joined Nov 2005
Apr 03, 2012 22:54 as a reply to  @ Haswell's post |  #6
Try this...
Get a Stroboflash Camera Flip Flash Bracket which is usually available on eBay for a very reasonable price. I got mine used for $15.00.
http://www.ebay.com …ories&hash=item​337433335c (external link)
I used a 550EX flash for these shots but the 430ex or 430EXii would be fine. I bounced the flash off the ceiling which was white and approximately 10 feet high.
I modified the bounced flash with a Joe Demb Flash Diffuser Pro www.dembflashproducts.​com (external link).
These are some indoor results from that single flash modified with the Flash Diffuser Pro with the FlipIt postion of the diffuser straight up...
IMAGE: http://rpcrowe.smugmug.com/photos/1244320241_7kTXJ-L.jpg
IMAGE LINK: http://rpcrowe.smugmug​.com …44320241&k=7kTX​J&lb=1&s=A  (external link)
IMAGE: http://rpcrowe.smugmug.com/photos/1245211250_kPtxT-L.jpg
IMAGE LINK: http://rpcrowe.smugmug​.com …45211250&k=kPtx​T&lb=1&s=A  (external link)
IMAGE: http://rpcrowe.smugmug.com/photos/1245211272_7qPdp-L.jpg
IMAGE LINK: http://rpcrowe.smugmug​.com …45211272&k=7qPd​p&lb=1&s=A  (external link)
Here are some outdoor results with a stucco wall as background and the flash pointed straight up with the FlipIt portion of the diffuser at a 45 degree angle forward...
IMAGE: http://rpcrowe.smugmug.com/photos/i-JrkG2Ch/0/L/i-JrkG2Ch-L.jpg
IMAGE LINK: http://rpcrowe.smugmug​.com …579394&k=JrkG2C​h&lb=1&s=A  (external link)
IMAGE: http://rpcrowe.smugmug.com/photos/i-fXNCtJ9/0/L/i-fXNCtJ9-L.jpg
IMAGE LINK: http://rpcrowe.smugmug​.com …581153&k=fXNCtJ​9&lb=1&s=A  (external link)
I also shot some two shots using the FlipIt straight up...
IMAGE: http://rpcrowe.smugmug.com/photos/1244551055_ox8GE-L.jpg
IMAGE LINK: http://rpcrowe.smugmug​.com …44551055&k=ox8G​E&lb=1&s=A  (external link)
IMAGE: http://rpcrowe.smugmug.com/photos/1245211231_aEf5x-L.jpg
IMAGE LINK: http://rpcrowe.smugmug​.com …45211231&k=aEf5​x&lb=1&s=A  (external link)
Haswell
Joined Oct 2011
Apr 04, 2012 12:24 |  #7
excellent; thank you very much.
HughR
Apr 04, 2012 13:21 |  #8
A good light modifier for the 430EX II is the Lumiquest Softbox III. I've been using one for about three years, and up to about 3-4 feet away from the subject it does a very good job. It's easily portable and inexpensive. Next step up would be something like the Cheetah Qbox (see the POTN Qbox thread). Using the 430EX off camera wirelessly as the key light and the pop-up providing a modest amount of fill (2:1-6:1), the 60D does a very nice job with portraits. You can place the key at 45° or 90° to the side or else on axis but above for butterfly or beauty lighting.
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
Haswell
Joined Oct 2011
Apr 04, 2012 17:28 |  #9
Great, I'll give it a good look. Thank you.
1,124 views & 0 likes for this thread, 5 members have posted to it.
NOOB flash
1070 guests, 114 members online
